Distributor wooooohs..?
Old Sep 4, 2003 | 09:26 PM
eastcostJDMfanatic's Avatar
Default Distributor wooooohs..?
i have 90 Dx and im getting no spark.. i put a buddies dizzy from his 91 dx and my car runs fine, so im assuming my dissy is bad. what exactly goes bad in the dizzy for it to stop working?.. ALSO will a distributor from a 90-91 crx si 1.6 work on a 90-91 Dx motor?
thanx
Old Sep 4, 2003 | 09:33 PM
Hoosier Daddy's Avatar
Default Re: Distributor wooooohs..? (eastcostJDMfanatic)
I would start with replacing the cap and rotor. Cheapest fix, and it definitely could be that.
Old Sep 11, 2003 | 05:29 PM
J's 94 Accord's Avatar
Go to Ebay get one for $30 to $50 shipped, you need dissy 1.5 from 88 to 91. that is what you need, dont throw youe money on something else, i had same problem.
Old Sep 11, 2003 | 05:33 PM
Go to Ebay get one 1.5 from 88 to 91 for $50 shipped. dont throw your money on something else, i had same problem
Old Sep 11, 2003 | 06:17 PM
zCivic's Avatar
Default Re: (J's 94 Accord)
you can make a SI work in a pinch... If its free and available use it. Unpin the plugs and swap them. The 2 sensor a DX uses are the same color and config as a SI. The SI only has the CPS just dont plug it in. Like you would have enough room in the square 5 wire plug
Old Sep 12, 2003 | 12:24 PM
Kidnkorner's Avatar
your coil, or ignitor may be bad
Old Sep 12, 2003 | 02:04 PM
hionvtecxda6's Avatar
Default Re: Distributor wooooohs..? (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear &raquo;</TD></TR><TR><TD CLASS="quote">your coil, or ignitor may be bad</TD></TR></TABLE>
before going out and buying another dist, change the coil.
Old Sep 12, 2003 | 02:38 PM
4crx4me's Avatar
yeah before spending money needlessly swap the coil and ignitor from your friends dizzy ONE at a TIME. NOT both at the same time. This should narrow down the problem. Unless the shaft seized, I can't see a dizzy going bad. It's solid state. look for loose or broken wires or connectors BTW. And use Di-electric grease.
HTH
92coupe
12
Nov 5, 2010 08:30 PM
1slowEF9
10
Jan 17, 2007 04:13 AM
classciv
Apr 2, 2006 03:30 PM
Agent Daimon
Dec 17, 2002 03:42 AM
blayzenazn
13
Mar 25, 2002 12:53 PM
