alignment with lots of negative CAMBER
my local just tires couldn't adjust toe on my EG hatch because it has over -1.5 camber . (the frickin lazor beams were off because of the camber made them point to ground ). I just wanted to know what all you guys are doing for toe when you are running very negative camber
it doesnt really madder cuase that camber is gonna wear the hell out of ur tires, so get some camber kits, in the front and in the rear, then worrie about the toe, u chould bring the toe in using a tape measure but ur tires are still gonna wear alot, if u dont no how to do that, take it to a place that uses the old hunter alignment machines, the new ones are crap and thats why the senors chouldnt read the readings.
negative camber is the bitch. i was eating tires every month
. i got my camber kit and everything is fine now
. what year car? you can get camber kits for cheap.
you don't necessarily need a camber kit in the rear. Search on how to fix your camber with a longer bolt and washers in the rear for just a few bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd8ch »</TD></TR><TR><TD CLASS="quote">i got the impression that toe in/out will wear your tires out faster than negative cambering</TD></TR></TABLE>was told the same thing by the guy who did my alignment.
killercrx91
Nov 3, 2008 01:00 AM
