type r intake manifold on b17 a with type R head
HI I recently swapped my cylinder head (b17a) witha b18c5 type r head. I also swapped the intake manifold. Now when I go to start the car there is gas spraying everywhere from like where the fuel rail meets the injectors. have I installed something wrong, or is it that I also need to buy a type r fuel rail to work with this setup. I have looked evrywhere for some step by step instructions on how to swap the intake manifolds but I have come up with nothing. when I go to start the car there is gas spraing from every injector. Please any help would be graet guys. Thanks!
You need to take out the injectors and check the o-rings, that should be the problem and ther should spacers between the fr and the injectors! Hope this helps bro good luck
Bense
Mar 14, 2007 02:18 PM
Bense
Mar 13, 2007 03:15 PM
