Prelude Cam Gears Question
Old Sep 4, 2003 | 07:40 PM
SohcPower93's Avatar
Default Prelude Cam Gears Question
Hi, im going with my friend next week to the track and we are gonna try to adjust the CAM GEARS but i really dont know which is a good setup for his car, he has a H22A motor with a PORT AND POLISHED HEAD, cold air intake, headers and exhaust so any sugestions in how to setup the CAM GEARS? thanks so much guys
Old Sep 4, 2003 | 11:32 PM
caLiH22A's Avatar
Default Re: Prelude Cam Gears Question (SohcPower93)
If he doesn't have cams' then I don't think he can adjust the cam gears, but I may be wrong. But say if he can adjust them I think what works best on an H22 is retardting the exhaust 2 degrees and advancing the intake 2 degrees, (-2, +2). Someone with more knowledge help me out here.
Old Sep 4, 2003 | 11:35 PM
JBG's Ferio's Avatar
Default Re: Prelude Cam Gears Question (caLiH22A)
I say you let someone who knows that they're doing adjust the cam gears.
Old Sep 4, 2003 | 11:38 PM
caLiH22A's Avatar
Default Re: Prelude Cam Gears Question (J B G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J B G &raquo;</TD></TR><TR><TD CLASS="quote">I say you let someone who knows that they're doing adjust the cam gears. </TD></TR></TABLE>
My question is can aftermarket cam gears be adjusted on stock cams?
Old Sep 4, 2003 | 11:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A &raquo;</TD></TR><TR><TD CLASS="quote">
My question is can aftermarket cam gears be adjusted on stock cams?</TD></TR></TABLE>
yes.
Old Sep 5, 2003 | 01:00 AM
NAR Cd7 Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower93 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, im going with my friend next week to the track and we are gonna try to adjust the CAM GEARS but i really dont know which is a good setup for his car, he has a H22A motor with a PORT AND POLISHED HEAD, cold air intake, headers and exhaust so any sugestions in how to setup the CAM GEARS? thanks so much guys</TD></TR></TABLE>
what powerband are you tuning for? midrange or top end?
if your going for midrange you would want to reduce the overlap/Lobe seperation angle, you can do this by retartding the Intake cam, and Advancing the exhuast cam
high end you want to tighten the LSA/ increase the overlap, by advancing the intake cam and retarding the exhuast cam
you retard/adv each cam by 2 degrees till you get no further gains, then you go to the next cam
you also need to re-adjust the timing after adjusting the camgears
CBR
Jul 31, 2005 08:51 PM
ironchef25
22
Feb 12, 2004 12:05 PM
01integraLS
Aug 1, 2003 12:28 PM
[DOD]Ak_RaPi$T~
Nov 17, 2001 01:42 PM
