popping/vibrating noise please help
ok i have just noticed in the past few days this popping noise coming from my drivers side front, whenever i take a corner to the right on my 97 accord. its only when i turned to the right though. i though it might be the cv joint but then i thought, well if the cv joint were bad, then it would pop no matter which way i turn. it doesn't do it at slow speeds. its like a constant pop almost like there is something on the outside of the tire. but i checked my tires. I have come to the conclusion that it may be a bad drivers side wheel bearing. or the guy at a local tire shop said it could be a bad bushing. if someone could please help me out here.
also, whenever i am between 1,000-1,500 rpm there is a vibrating noise coming from the right side front of my car. it sounds like something is vibrating whenever i give it gas to start off or whenever i am slowing down downshifting. its only between 1,000 and 1,500 rpm though.
also i have some parts for sale if anyone needs them, for a 94 accord.
I have the stock am/fm cassette radio (i can get the code if you need it) $40 o.b.o.
right and left front shocks (used) $15 a piece or $25 for both
factory lx exhaust rear section $60
i aslo have a pair of brand new 94-97 turn signals ($5)
lemme know if anyone wants those parts. they were on my 94 lx that was totalled about a month ago.
DrunkNRacer
Oct 10, 2003 04:03 AM
