JDM ITR Header
Old Sep 4, 2003 | 06:15 PM
j_hartwell's Avatar
Default JDM ITR Header
ok, im buying a JDM 98 spec ITR header. I drive a 99 gsr. The guy im getting it from is also giving me a test pipe with a 2.5 inch collector at the tip that mushrooms out. Will have to do any other modification so that it will bolt up to my gsr? Some peeps say im gonna need a high flow cat. Please help
Old Sep 4, 2003 | 06:35 PM
B2FiNiTY's Avatar
Default Re: JDM ITR Header (j_hartwell)
If you have a straight pipe already, you won't need a high flow cat. You can only use one or the other unless you want to be stooopid.
Old Sep 4, 2003 | 06:46 PM
j_hartwell's Avatar
im not running a straight pipe though. i just need to know if i bolts up.
Old Sep 4, 2003 | 06:48 PM
jdmspoonitr's Avatar
Default Re: (j_hartwell)
most likely need to hack the b-pipe
Old Sep 4, 2003 | 07:02 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (jdmspoonitr)
Never mind, I'm an idiot...
You will probably need a custom cat or test pipe built to mate the 2.5" collector to the GS-R b-pipe.
Bloody Hatch
Sep 18, 2012 05:59 PM
slateEKsi
Jul 26, 2010 04:06 PM
blackhbkid
Feb 7, 2009 09:44 PM
type-GGSR
Mar 4, 2008 09:25 PM
95GSRBOI
May 4, 2006 06:06 PM
