Which spark plug to use ?
Old Sep 4, 2003 | 05:54 PM
shannon's Avatar
Default Which spark plug to use ?
Which spark plug will be the best plug for an all motor b18b1 with cai and hi flow exhaust?
Old Sep 4, 2003 | 05:57 PM
projecthybrid04's Avatar
Default Re: Which spark plug to use ? (shannon)
bosch platnum, 1 prong
Old Sep 4, 2003 | 06:51 PM
Turbo12acer's Avatar
As a mechanic, i would have to say NGK because it for Imports. I would have to say V-power plugs. Unless you have some heavy mods done in motor. List up what you have done on engine.
Old Sep 4, 2003 | 07:06 PM
Eyewitness's Avatar
Default Re: (Turbo12acer)
Find out from acura the part # for your plugs....they should be like 20.00 bux a piece and NGK...you want to get these for reasons i cannt explain to you becasue i forgot them...someone elaborate
Old Sep 4, 2003 | 08:54 PM
MrTodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo12acer &raquo;</TD></TR><TR><TD CLASS="quote">As a mechanic, i would have to say NGK because it for Imports. I would have to say V-power plugs. Unless you have some heavy mods done in motor. List up what you have done on engine.</TD></TR></TABLE>
Just as he said. Use the factory recommended plugs, you will get the most power out of those. It's been dyno proven. Always stick with NGK, even with mods there are certain NGK plugs that will be best suited for your application.
Old Sep 5, 2003 | 04:48 AM
dip-set's Avatar
NGK- ZFR5F-11
i just swapped out the plats in my ls for these (copper) plugs...noticable difference...
Old Sep 5, 2003 | 10:10 AM
Arsenal's Avatar
Default Re: Which spark plug to use ? (teg-your-it)
The NGK are 9.99 a piece, thats 40 dollors for spark plugs?
Old Sep 5, 2003 | 11:24 AM
Eyewitness's Avatar
Default Re: Which spark plug to use ? (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">The NGK are 9.99 a piece, thats 40 dollors for spark plugs?</TD></TR></TABLE>
Yes....there even more at some places
Old Sep 5, 2003 | 01:15 PM
dip-set's Avatar
Default Re: Which spark plug to use ? (Eyewitness)
cause your buying plats..get the coppers..better conductor and u can get all 4 for about 10 12 bucks....
Old Sep 5, 2003 | 06:33 PM
shannon's Avatar
Thank you guys for the info.
Old Sep 5, 2003 | 08:03 PM
accually you shouldnt use plat plugs. With my experiance, plat. plugs are used for cars boosted or super charged. If you use plat. plugs in your car running all motor it will run poorly. Get some V-power or Iridium.
Old Sep 5, 2003 | 08:04 PM
If you let me know the plug numbers i can probally get them sent to you for cheaper then you can probally get them for. e-mail me if interested Eddie10086@***.net
Old Sep 6, 2003 | 07:05 AM
Audi RS4's Avatar
Lover
OEM
kevaccord
May 10, 2007 01:29 PM
Midori Green
26
Nov 25, 2006 05:39 PM
Calean007
May 9, 2005 07:04 PM
7rrivera7
Sep 30, 2003 12:55 PM
