Need advice for increasing fuel delivery
Old Aug 18, 2001 | 11:20 AM
ninjaman's Avatar
New User
Default Need advice for increasing fuel delivery
Ok, a wideband O2 sensor indicated that I'm running very lean (about 13.4 @ WOT) at ~6500 rpm. This was with my fuel pressure at 58psi and my VAFC cranked up to +18 (any higher made no difference -- maxed out). It looks to me as though the stock system just isn't enough anymore. How should I appropriately upgrade my fuel system? I plan to get the Skunk2 ecu which runs rich, but I am still wondering if I'm over taxing my fuel pump and injectors.
My mods:
- Skunk2 cams w/ gears at +3(in), -2(ex)
- Skunk2 IM
- DC JDM header w/ Carsound cat and Tanabe exhaust modified to complete 60mm ID
- ITR AEM CAI
- VAFC
- B&M FPR
Note my timing is at 18 degrees and my engine has always been on the strong side relative to other B18Cs.
Old Aug 18, 2001 | 08:39 PM
ninjaman's Avatar
New User
Default Re: Need advice for increasing fuel delivery (ninjaman)
ttt
Old Aug 18, 2001 | 11:26 PM
sgT's Avatar
sgT
13.5 isnt really lean. Past 14.7 is lean.
13-13.5 is about where an NA car should be.
My suggestion is to do a pull on the dyno and shut the motor off immediately
after hitting redline. Then check the plugs. That will give you a better estimation.
johnzm
Sep 18, 2004 04:49 PM
96redgsr
Jul 25, 2004 08:32 AM
DIE DIE
Mar 2, 2004 08:13 PM
oryanh
Mar 25, 2003 03:57 PM
