For those who went "WINGLESS"
Old Sep 4, 2003 | 04:11 PM
B00ST2nR's Avatar
Default For those who went "WINGLESS"
How did you plug the holes? What's a good way to cover up the holes without goin to the Body shop and filling the holes and re-painting them?
I decided to go Wingless now, but the holes are just nasty. Give me some good advice.
I posted this in the Integra forum too, but I figured Type-R owners would have gone wingless more than other Integra owners, since ITR's come with Spoilers from the factory.
If you know any good tips or advices, let me know. Thanks.
Old Sep 4, 2003 | 04:17 PM
Padawan's Avatar
Darth ModerVader
Default Re: For those who went "WINGLESS" (Skunk2nR)
I got some plastic plugs from the local body shop, had them sprayed to match my paint, then used silicone sealant/adhesive to secure them. It looked very clean, and was basically the next best thing to having the holes permanently shaved.
Old Sep 4, 2003 | 04:21 PM
1GreyTeg's Avatar
Whats that a GSR with wing? Had the light up wing and those are the holes for the wires right?
The R wing only has 2 holes on each side and I just plugged them with plastic caps from Honda, The stock number escapes me now I can find it later.
I have since reinstalled the wing though
Old Sep 4, 2003 | 04:38 PM
DC*1327's Avatar
Default Re: For those who went "WINGLESS" (1GreyTeg)
for all you itr's who went wingless, if you want to sell your wing let me know.
btw i used black duck tape when i went wingless (yeah i know its ghetto, but my car is black)
Old Sep 4, 2003 | 04:42 PM
H-PIMP's Avatar
Default Re: For those who went "WINGLESS" (99B18C1327)
Solution: Put the wing back on! Wingless is ghey, the wing on an R is functional, it actually reduces lift under high speed braking and lane changes.
Old Sep 4, 2003 | 04:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: For those who went "WINGLESS" (H-PIMP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-PIMP &raquo;</TD></TR><TR><TD CLASS="quote">the wing on an R is functional, it actually reduces lift under high speed braking and lane changes.</TD></TR></TABLE>
Well, technically it reduces lift during high-speed anything.
Old Sep 4, 2003 | 04:54 PM
barto's Avatar
Default Re: For those who went "WINGLESS" (Padawan)
would you consider reducing lift to be the same thing as downforce?
Old Sep 4, 2003 | 04:56 PM
skafia's Avatar
25 Year Member
Default Re: For those who went "WINGLESS" (barto)
I just used white electrical tape and covered it up.
Old Sep 4, 2003 | 05:00 PM
baonest1's Avatar
Default Re: For those who went "WINGLESS" (skafia)
i used white duct tape on my car.. but man, i left it on for a looooooooong time. had to use some 3m adhesive remover on that.
Old Sep 4, 2003 | 05:04 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barto &raquo;</TD></TR><TR><TD CLASS="quote">would you consider reducing lift to be the same thing as downforce?</TD></TR></TABLE>
I don't believe the ITR wing contributes any positive downforce. As stated, it simply reduces the amount of lift being generated.
Old Sep 4, 2003 | 05:09 PM
GokuSSJ4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">I just used white electrical tape and covered it up.</TD></TR></TABLE>
does it leak went it rains ??
Old Sep 4, 2003 | 05:12 PM
Padawan's Avatar
Darth ModerVader
Default Re: For those who went "WINGLESS" (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">does it leak went it rains ?? </TD></TR></TABLE>
The holes from the ITR wing do not enter the cabin, so there would be no leaking even if they were left uncovered.
Old Sep 4, 2003 | 05:25 PM
1GreyTeg's Avatar
Found the number of the plugs
Honda stock # 91601-SR3-000
Do what you want, it's your car.
I had mine off for over a year but reinstalled it once I started to frequent tracks.
And you can feel more stability with the ITR wing on, You can especially feel it when braking from high speeds. But, as stated I doubt it creates major downforce.
Good luck,
A.
Old Sep 4, 2003 | 05:26 PM
Big Teggie's Avatar
Go to ACE Hardware and in the hardware aisle they have all sorts of plugs. I just found some cheap ones, and picked up a bunch in different sizes.
I dont have any pics of the plugs themselves, but here they are installed.
Old Sep 4, 2003 | 05:41 PM
B2FiNiTY's Avatar
Default Re: For those who went "WINGLESS" (Big Teggie)
I got the oem plugs. They are great. You can find them on 92-95 civics where the holes are for the strut tower bar and 94-01 integra ls/gs etc where the strut tower bar is supposed to be.
Old Sep 4, 2003 | 06:02 PM
B00ST2nR's Avatar
Default Re: For those who went "WINGLESS" (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I got the oem plugs. They are great. You can find them on 92-95 civics where the holes are for the strut tower bar and 94-01 integra ls/gs etc where the strut tower bar is supposed to be. </TD></TR></TABLE>
got any pictures?
Old Sep 4, 2003 | 06:15 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">
got any pictures?</TD></TR></TABLE>
I have 4 OEM rubber plugs. They are yours, if you want to pay $10 for them shipped to your door. I got no use for them. My wing is back on! :gasp:
pic:
Modified by Cosworth at 10:50 PM 9/4/2003
Old Sep 4, 2003 | 06:30 PM
B00ST2nR's Avatar
Default Re: For those who went "WINGLESS" (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">
I have 4 OEM rubber plugs. They are yours, if you want to pay $10 for them shipped to your door. I got no use for them. My wing is back on! :gasp:</TD></TR></TABLE>
4 plugs for the small one? I might buy it from you... lmk-
Old Sep 4, 2003 | 06:33 PM
B2FiNiTY's Avatar
$10 is a pretty good price. Buy from Sean, great guy
Old Sep 4, 2003 | 07:08 PM
B00ST2nR's Avatar
Default Re: For those who went "WINGLESS" (b19coupe)
Ok. I went to Lowes and looked for the plugs. They didn't have any. So I went to Walmart to buy some White tape, to match my car.
I got me some heavy duty sticky "Waterproof" tape in White and put a piece on it. Here's what it looks like now:
Doesn't look too bad huh? I'll probly leave it until later when I decide to shave my side moldings along with the holes on the trunk...
Old Sep 4, 2003 | 07:10 PM
Cosworth's Avatar
Put the tape from the other side. So, that the adhesive won't ruin your paint after being under the weather.
Old Sep 4, 2003 | 07:14 PM
DC*1327's Avatar
looks real good
Old Sep 4, 2003 | 07:24 PM
is3oo's Avatar
Just get plugs and paint them white. I think it wouuld look cleaner. Tape is kinda ghetto.
Old Sep 4, 2003 | 09:09 PM
ITR#JohnBasedow's Avatar
Default Re: For those who went "WINGLESS" (Type-Rizzle)
I have PY with black plugs. Black wingless cars look better because the plugs are black.
Old Sep 4, 2003 | 09:13 PM
B00ST2nR's Avatar
Default Re: For those who went "WINGLESS" (ITR0863)
screw it. I'm gonna goto a Body Shop and get it done.
