I need to know what the MAP sensor voltage should be.
I need to program my Zdyne with the MAP voltage and my new chilton doesn't have that info, the old chilton did. So i need to know what the voltage is supposed to be.
It will vary depending on engine load. The Helms for the del sol says at idle voltage should be 5V. It should apply the same for EF's.
