axels question on 91 hatch std
the stock axles should work. to my knowledge the only thing you have to watch with the 91's is if it has 23 or 26 splines on the hub side, as long as that is all good it will work.
Everything will be fine. Im almost 100% positive that the inner joint on the STD axles are the same spline count as the Si axles. The outer joint is the main difference. Just be careful when installing the axles, make sure things go together smoothly. HTH
CW-ITR
May 20, 2009 07:25 PM
2fast4udude
Aug 28, 2005 09:14 PM
