will motor fit in integra?
Old Sep 4, 2003 | 03:15 PM
str8drift's Avatar
Default will motor fit in integra?
i wanna put a 95 ls motor into a 90 91 integra. what will i have to do to make this fit?
Old Sep 4, 2003 | 03:24 PM
rodrez.'s Avatar
Default Re: will motor fit in integra? (str8drift)
It bolts in.
Old Sep 4, 2003 | 07:49 PM
hybrid93SIvic's Avatar
Default Re: will motor fit in integra? (rodrez)
bolts right in
Old Sep 4, 2003 | 08:37 PM
6infected6soul6's Avatar
Default Re: will motor fit in integra? (hybrid93SIvic)
i think you need to keep the sensors and stuff off of the old motor because the new motor is obd1. and you definitely need to swap over the distributor...
Old Sep 4, 2003 | 09:07 PM
str8drift's Avatar
Default Re: will motor fit in integra? (6infected6soul6)
which dist. do i need to use? so you guys are sayin to use just the block?
ect. intake manifold,dist,throttle body, what else?
Old Sep 4, 2003 | 09:40 PM
Audi A4's Avatar
are u getting a long blk or a swap? im near u btw
Old Sep 4, 2003 | 09:45 PM
str8drift's Avatar
Default Re: will motor fit in integra? (DRAG lll INTEGRA)
i'm trying to look for a motor actually. i'm buying a 91 ls and the rod bearings went bad. so i have a friend that said he got a b18b. any help would be great. if i can find just a stock 90-91 motor, that would be fine too. got aim? or a fone number?
MadCityVtec
Feb 17, 2009 11:08 PM
89_integra_ls
Aug 29, 2007 04:09 PM
skylinecivi
Welding / Fabrication
May 27, 2005 09:41 AM
imaginary17
Aug 9, 2004 12:48 AM
94lsvtec coupe
Aug 25, 2002 07:53 PM
