How many whp should I expect by the AN-R???
Old Sep 4, 2003 | 03:04 PM
SOHC_DK.'s Avatar
Default How many whp should I expect by the AN-R???
I was just wondering how much better the AN-R header is, compared to the DC 4-1.. how much more could I expect????
The engine is a B16a2... with random highflow cat, SP catback and a short air intake...
M. Nielsen
Old Sep 4, 2003 | 04:38 PM
teg92's Avatar
Default Re: How many whp should I expect by the AN-R??? (SOHC_DK.)
I'd be really happy with 5whp, but there really aren't enough people with it to be able to accurately predict. Do us all a favor and let us know before & after! good luck
Old Sep 4, 2003 | 05:40 PM
Charlie Moua's Avatar
well you should let us know what mods you have already and what WHP it makes right now...then we could give you a more accurate guestimate.
cams and compression is going to make a big differece.
Old Sep 4, 2003 | 05:44 PM
g5r's Avatar
g5r
Default Re: How many whp should I expect by the AN-R??? (Charlie Moua)
is there a way to make the street version (compact) of the header to clear a/c?
Old Sep 4, 2003 | 11:21 PM
SOHC_DK.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">well you should let us know what mods you have already and what WHP it makes right now...then we could give you a more accurate guestimate.
cams and compression is going to make a big differece. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK &raquo;</TD></TR><TR><TD CLASS="quote"> The engine is a B16a2... with random highflow cat, SP catback and a short air intake... </TD></TR></TABLE>
Right now I have a standard header. The last dyno I did was with a "Ebay-header"(200$) and with that on it made 162 HP measured at the flyweel, not whp!!
But 5 more Hp on the flywheel is also 5 more whp...(example)
Right now with the standard header I actualy have no dyno-result, but my butt-dyno says it's about the same.. no difference..
M. Nielsen , Denmark
Old Sep 5, 2003 | 04:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK. &raquo;</TD></TR><TR><TD CLASS="quote">The engine is a B16a2... with random highflow cat, SP catback and a short air intake...
M. Nielsen </TD></TR></TABLE>
well with just those mods don't be suprised if you lose some low end power. AN-R headers are mainly for a mild to wild NA setup. If you want you can/should get them now and just wait for additional power. Get a good exhust and some good cams (CTR, skunk2-1... or above that range) cam gears and something like a 11:1 or higher compression ratio and the header will be worth it. you'll have a mild setup that you'll be proud of.
HTH
Old Sep 5, 2003 | 04:48 AM
Casey's Avatar
Im going to test the an-r in a few weeks when mine comes in. Im at 182/131 right now. IM going to add the an-r header(non compact, regular collector) and the an-r IM gasket. I hope to break 190/135. but if i make 5whp, ill be satisfied. Just thinking it might be more than that, but who knows, untill i i do it
honda_coupe
26
Apr 27, 2007 02:24 PM
quik2kSi
14
Dec 24, 2004 05:59 PM
smart monkey
11
Jun 28, 2004 09:54 AM
2nrDren320
Jan 4, 2004 08:31 PM
93GSRB17
Aug 22, 2003 03:47 PM
