Subs will they hook up to stock unit?
Old Sep 4, 2003 | 03:03 PM
dacaveman's Avatar
Default Subs will they hook up to stock unit?
Ok I have the stock 6 disc player in my car and I just bought some 12'' subs off my friend and I wanted to hook them up in my car so I am going to go to best buy and get everything wired up by them. So its dont right and I wont mess anything up. But is it possible to hoop up the subs to the stock head unit I also have a amp with the subs. Im not sure if this will work or not. Does anyone else have this done to the there car?
THANX
Old Sep 4, 2003 | 03:54 PM
zzwannabedjzz's Avatar
yes it is possible to hook it up, the only problem is the stock unit gives u less power, and that u need to buy a harness which is really cheap, other than that it is fine.
Old Sep 4, 2003 | 03:56 PM
JimmieD's Avatar
Default Re: Subs will they hook up to stock unit? (dacaveman)
yes, in my last few cars i run a 4 channel amp to the fronts and use the rear channels bridged to run the sub. I keep the rears off the stock head unit or i run them with the fronts (no fade).
This is a great set up for good sound without the hassle of people looking into you car to steal a system.
Go to your local stereo installer and they can hook you up!
Old Sep 4, 2003 | 04:46 PM
03 civic si hb's Avatar
what you need is a line out converter, it turns your speaker leads into a rca pre out. you lose a little signal but if you want a stealth looking system this is the way to go. a good line out converter with an ajustable gain control with cost about 20 to 25 bucks
Old Sep 7, 2003 | 02:16 PM
tightDA8's Avatar
it will hook up and sound fine....in my EP3, i have a fostgate punch 360 amp and a kicker comp vr 12 hook up to the stock head unit and stock mids and tweets through a converter...it looks stock and sounds very good...a 12 inch sub in a hatchback with a good box bumps pretty hard..
collkid
Audio / Security / Video
Oct 31, 2017 03:01 AM
PSI240SX
Feb 16, 2010 04:47 PM
blueinfinity
Sep 29, 2004 01:55 PM
VTECPWR
May 16, 2002 09:49 AM
