My trunk wont open
Old Sep 4, 2003 | 02:51 PM
Denny's Avatar
Default My trunk wont open
sorry this is a little OT but my trunk wont open. my question is, is the trunk is the trunk latch mechanical or eletrical (the think you turn right to open)? i did a s2k antenna conversion and everything went well and now my trunk wont open. when i press the alarm, you can still hear my trunk lock or unlock. any ideas on how to fix it? any help will be appreciated.
Old Sep 4, 2003 | 02:54 PM
TypeR 599's Avatar
Default Re: My trunk wont open (Denny)
sometimes mine doesn't open. using the key in the keyhole pops it open everytime though.
Old Sep 4, 2003 | 02:57 PM
hYpE-R-29's Avatar
its the trunk latch motor...mine did the same thing it would open with the key and I could hear it unlock with the remote but when I tried to open the trunk by hand with the latch it wouldnt...so i took it to the dealer, and said my motor went bad so they gave me a new one...U under 50,000 miles???
Old Sep 4, 2003 | 02:58 PM
Denny's Avatar
Default Re: My trunk wont open (hYpE-R-29)
okay cool. ill try that right now and see if it works. thanks, and yes im under 50k
Old Sep 4, 2003 | 02:59 PM
98R-1144's Avatar
Default Re: My trunk wont open (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes mine doesn't open. using the key in the keyhole pops it open everytime though.</TD></TR></TABLE>
same thing w/my friends GSR..the latch never opened it anymore..but using a key worked everytime!
Old Sep 4, 2003 | 03:05 PM
Denny's Avatar
Default Re: My trunk wont open (98R-1144)
just tried the key, doesnt work. im just very fusterated right now. my dealership always gives me hard time b/c ive had about 10k is warranty service done, had to get new suspension, new tranny, new motor(whole motor) all under warranty. is the latch thingy electrical or mechanical? any other suggestions?
Old Sep 4, 2003 | 03:14 PM
MiraiZ's Avatar
I'm pretty sure that the ITR trunk lock is mechanical...try removing the rear panel; there should be a cable that unlatches the trunk...try tugging on it to open the trunk...the cable may be jammed or damaged..
Old Sep 4, 2003 | 03:17 PM
Denny's Avatar
Default Re: My trunk wont open (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure that the ITR trunk lock is mechanical...try removing the rear panel; there should be a cable that unlatches the trunk...try tugging on it to open the trunk...the cable may be jammed or damaged..</TD></TR></TABLE>
i cant even open the trunk, how am i supposed to get to it?
Old Sep 4, 2003 | 03:19 PM
sackdz's Avatar
THe 98+ Integra has no cable mechanism...
Old Sep 4, 2003 | 03:22 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">
i cant even open the trunk, how am i supposed to get to it?</TD></TR></TABLE>
crawl through the back seat...
REALLY??...the trunk is not cable operated??? The latch feels like its connected to some kind of cabling system...
Old Sep 4, 2003 | 03:23 PM
TypeR 599's Avatar
Are you sure you turned the key as far as you can clock wise? force it
Old Sep 4, 2003 | 03:25 PM
Denny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you turned the key as far as you can clock wise? force it </TD></TR></TABLE>
yes, you can hear the motor working. you hear it unlock and lock.
Old Sep 4, 2003 | 03:31 PM
MiraiZ's Avatar
This is a Type R?? I wonder if the lockin mechnism is different on USDM and JDM R's...mine does not make a motor noise...it just pops the trunk when the key is turned.....
Sorry...don't mean to hijack this thread...just find it odd......maybe the trunk itself (not the lock) is stuck...I get this especially after a hot day...
Old Sep 4, 2003 | 03:32 PM
yoshi234's Avatar
I shoot brides
Denny:
turn the key all the way to the right - turn the key and it stops and from there it should turn a little more. Once it's turned all way, lift up on the hatch at same time.
yshi - who had to do this on aoigsr's kaa
Old Sep 4, 2003 | 03:33 PM
Denny's Avatar
yeah its a pop sort of sound, sorry about the misunderstanding
Old Sep 4, 2003 | 03:34 PM
Denny's Avatar
Default Re: My trunk wont open (yoshi234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">Denny:
yshi - who had to do this on aoigsr's kaa</TD></TR></TABLE>
will try again right now. this this is really fustrating me
Old Sep 4, 2003 | 03:35 PM
hYpE-R-29's Avatar
DUDE...go in the trunk through the back seat....dont act like you havent dont it before
Old Sep 4, 2003 | 03:39 PM
Denny's Avatar
blah nothing works
Old Sep 4, 2003 | 03:45 PM
Denny's Avatar
finally got it to work!! i just kicked my car and now it works again!! literally i kicked my car and now it works
Old Sep 4, 2003 | 03:46 PM
TopNotchR's Avatar
mine don't work either...i have to go through the back seat....sucks
Old Sep 4, 2003 | 03:58 PM
yoshi234's Avatar
I shoot brides
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">finally got it to work!! i just kicked my car and now it works again!! literally i kicked my car and now it works </TD></TR></TABLE>
kicking, punching, slapping, hitting usually does wonders
Old Sep 4, 2003 | 04:25 PM
Splat's Avatar
Collector-o-Guns and Drinker
kicking, punching, slapping, hitting usually does wonders </TD></TR></TABLE>
j00 forgot swearing and yelling
Old Sep 4, 2003 | 05:50 PM
B2FiNiTY's Avatar
hahah, that is hella funny. Glad you got it worked out so you didn't have to bust out the hammer
Old Sep 4, 2003 | 05:58 PM
Haunt's Avatar
Sad...but true... Glad you got your trunk working...
Old Sep 4, 2003 | 06:49 PM
geometro's Avatar
Default Re: My trunk wont open (sackdz)
I'm curious if there is any way to retro fit the 98+ latch mechanism with one that isn't electrically operated...
Anybody out there with some experience on this?
George
