flywheel ?
Old Sep 4, 2003 | 01:34 PM
mild98's Avatar
Default flywheel ?
I want to know is it really worth it to get a lightweight flywheel? I am in the process of changing the clutch and wondering. 250.00 sure is alot to spend to learn something. For my broke *** anyway.
Old Sep 4, 2003 | 03:57 PM
Fobtions's Avatar
Default Re: flywheel ? (mild98)
once you get a flywheel, youll never go back to stock. i love mine. cusco 8lbs.
Old Sep 4, 2003 | 04:23 PM
blueHwrench's Avatar
Default Re: flywheel ? (Fobtions)
I think what you need to ask yourself is what do you use this car for? A lightened flywheel does three things: 1. reduces overall weight of vehicle. 2. reduces weight at crankshaft, therefore SHOULD gain some hp (especially at peak rpm) 3. reduces rotating mass at crankshaft, which WILL increase the rate at which the engine can gain rpm (it revs quicker). It also has a detrimental effect on drivability, i.e.- low rpm, low speed driving; you will most miss a reg. flywheel in stop and go traffic. So, if you do alot of cummuting, say no. If you want strictly performance gains, say yes. What I do recommend you do, no matter what flywheel you choose to run, is have the whole clutch/flywheel assembly balanced, before you install it. This will do more longevity of that engine than most things you can do for it. Balanced rotating mass is a beautiful thing.....
Old Sep 4, 2003 | 04:28 PM
Outsane's Avatar
Default Re: flywheel ? (blueHwrench)
you can always have one lightened..
I had one at 12lbs.. and loved it..
and 12lb is considered safe....stock is 19
Old Sep 4, 2003 | 09:48 PM
91 POS's Avatar
How much dose it cost to get one lightened??
Old Sep 4, 2003 | 10:33 PM
GIAMotorSports's Avatar
That is pretty much all you need to know
Old Sep 4, 2003 | 11:00 PM
Outsane's Avatar
Default Re: (91 POS)
I did mine for $100..
Old Sep 4, 2003 | 11:09 PM
91 POS's Avatar
Default Re: (Outsane)
How much did you have it lightened??
Old Sep 4, 2003 | 11:12 PM
Outsane's Avatar
from 19 to 12lbs as I said up above..
Old Sep 4, 2003 | 11:13 PM
sporkcrx's Avatar
Default Re: flywheel ? (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">I had one at 12lbs.. and loved it..
and 12lb is considered safe....stock is 19</TD></TR></TABLE>
edit: ****, beat me to it
Old Sep 4, 2003 | 11:17 PM
91 POS's Avatar
Thanks for the help guys. What area did they machine off to drop that much weight??
Old Sep 4, 2003 | 11:33 PM
Outsane's Avatar
drilled holes in the flywheel surface area... alot like a drilled brake rotor...
I never slipped a clutch after wards...
Old Sep 4, 2003 | 11:35 PM
Outsane's Avatar
ok I was kidding..
on the opposite side of the surface area.. thats the only place to take off weight..
flattened most of it.. and took a little extra off the outside... is the outer most wieght that makes a difference when things are spinning..
Old Sep 4, 2003 | 11:39 PM
91 POS's Avatar
What size and how many holes were they? The reason i ask is that I am a machnist and I will just do it myself on a rotary table
Old Sep 5, 2003 | 12:34 AM
91 POS's Avatar
I guess my typing skills were not fast enough. Thanks for the info.
Old Sep 5, 2003 | 01:29 AM
NA gs-R 05 C
Guest
Posts: n/a
you might as well get a good flywheel while you're in the process of changing your clutch, and btw, what kinda clutch are you getting, if the clutch is real harsh, it will eat away at your flywheel (stock), so it would be better to get an aftermarket fly anyways.
Old Sep 7, 2003 | 07:59 AM
Tyteteg119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueHwrench &raquo;</TD></TR><TR><TD CLASS="quote">1. reduces overall weight of vehicle.
This is not relevant your talking about a few pounds at the crank, but you migh be talking about how it makes the vehicle appear lighter to the engine.
A light weight FW will NOT give you any higher peak HP or Torque
You said three things but they all are the same.
Simply PUT the advantage of a Lightweight FW is Acceleration. Bottom line. the Car is able to accelerate quicker. This is the purpose of a Lighter FW in a performance arena. The Lighter the FW the Quicker the Acceperation. and the less drive able the car becomes on the Street (Stop and go Traffic)
put it this way many people will say they enjoy the light FW and their FW is 6 pounds and it is totally streetable, but the fact is that it is a USER PREFERENCE.
Since there is less store energy in the FW the RPMS will fall off as quickly as they increase.
Decrease in fuel Economy, more wear and tear on the drive train due to lack of consistency. I enjoy my 10.5 pound FW it is a dream to drive and not too much different in drivability.
BTW this has been discussed in the tech forum it's a good thread on the subject
IntegraJdmb18c1
Dec 26, 2005 01:28 PM
ELITE 350Z
Apr 14, 2004 12:57 AM
IdotheSHOCKER
May 23, 2002 03:10 PM
FORTIS
Feb 12, 2002 08:52 AM
thrombosis
Sep 20, 2001 07:00 AM
