got some 405 LS non vtec crower cams not sure if i can run them or not, help me
Old Sep 4, 2003 | 01:28 PM
djay86's Avatar
Default got some 405 LS non vtec crower cams not sure if i can run them or not, help me
Well I wanted the Crower 405a's but i believe i got the 405's..
This is for a b18a non vtec motor.
The duration of this cam is 270, 270 and the lift is .502 .502
Does anyone think i can get these cams to idle without a EMS?
Old Sep 4, 2003 | 04:47 PM
teg92's Avatar
Default Re: got some 405 LS non vtec crower cams not sure if i can run them or not, help me (djay86)
Speaking from experience:
First off with those cams you will not have sufficient rocker arm clearance without machine work to the bottom spring retainer/seat. Without modification you could royally mess up your head. You'd have to bring it to a head porter or engine shop and supply them with the cams to make the appropriate modifications. Its not a DIY job.
As for idling, you will definately not be idling very well anything under 1200rpm even with an EMS.
Modified by teg92 at 10:18 PM 9/4/2003
Old Sep 4, 2003 | 05:24 PM
djay86's Avatar
Default Re: got some 405 LS non vtec crower cams not sure if i can run them or not, help me (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">Speaking from experience:
First off with those cams you will not have sufficient rocker arm clearance without machine work to the bottom spring retainer/seat. Without modification you will easily eat up your valve seals or could royally mess up your head.
As for idling, you will definately not be idling very well anything under 1200rpm even with an EMS. </TD></TR></TABLE>
what exactly needs to be done to the bottom spring retainer seat?
Old Apr 18, 2004 | 11:04 PM
untitled's Avatar
back from the dead b/c i need to know.
Old Apr 25, 2006 | 12:10 AM
kahren's Avatar
Default Re: got some 405 LS non vtec crower cams not sure if i can run them or not, help me (untitled)
teg92, what exactly has to be done to the bottom spring retainer/seat?
i am wondering as well.
Old Nov 19, 2010 | 08:04 AM
integkc's Avatar
no need for any work to be done on the head had the same one's i did break a rocker arm but replaced and just made dual valve springs use orig from ls and the inners from b16 intake side. worked awsome, and for idle if u have ur ecu chip have u ever shipped it lower ur rpms and then advance ur timeing.
Old Nov 19, 2010 | 08:05 AM
integkc's Avatar
and i just noiced this was a very old post
Old Nov 19, 2010 | 08:46 AM
fv8s's Avatar
Way to bring it back from the dead. not a smart idea to run these cams on a somewhat stock valvetrain (your an idiot if you do). It would be tough to get a nice idle also
Old May 15, 2013 | 10:21 PM
Jimmynitro's Avatar
Nothing wrong with adding to old threads. As I just pick these cams up today and this thread answered my question on the spring seat. Bump lol never know whos looking for info on what
Old May 16, 2013 | 11:14 PM
Jimmynitro's Avatar
Just put my 405a-2 in my p75 head few minutes ago, and there close to the rocker nuts but do have clearance and should wrk fine.
Old May 17, 2013 | 11:27 AM
darnizzle8805's Avatar
Man I would love to have some 405's or 405a's. I am currently running the original 404's, which I love, but as always there is more to be desired. Going to a vtec head is not an option, unless I cant break into the 12's with my 2500lb DA. If I do put my vtec head on, I have already locked vtec. The only way to go in my opinion.
Old May 17, 2013 | 08:24 PM
Nonvtec eg6's Avatar
I run the old school 405 but they didn't clear the rocker bolt so I send them back to crower to take some lift off. I currently run 11.7 with my B20 nonvtec motor (all motor)
Old May 20, 2013 | 06:07 AM
Nonvtec eg6, what is your race weight? I have run 13.8 so far on a basic tune with my 2500lb 91 Integra, going back after I swap my transmission so hopefully I can gain a couple tenths. I know a tune will help loads, and I will eventually get to the dyno. But I might just wait until I get my b20 block together, instead of dumping all of my money into my LS. But I am nonvtec all the way.
Old May 20, 2013 | 03:36 PM
Havent hit the scales yet but I estimate is around 1800
TopEndTuner
Aug 16, 2008 11:28 AM
dohc_profile
Nov 13, 2007 08:32 AM
90teg
Jan 27, 2004 09:40 AM
Komsomol
Sep 15, 2003 11:40 AM
LBR92DA-T
Jun 27, 2003 12:34 AM
