SIR hood....does it add under hood clearance?...how much?
Old Sep 4, 2003 | 12:05 PM
*Boostwerks*'s Avatar
Default SIR hood....does it add under hood clearance?...how much?
I need about an 1" of clearance for my setup to clear properlly...
The front 2 manifold runners are hitting.
will the Fiber images USDM SIR hood do the trick?
I can get it to the safety latch, but it's just not enough room to latch securly with enough room for engine movement.
Thanks for any help!
Bryson
Old Sep 4, 2003 | 12:10 PM
roadawg's Avatar
Default Re: SIR hood....does it add under hood clearance?...how much? (Bryson)
I wish I could help you, but anyway.
Nice setup
Old Sep 4, 2003 | 12:25 PM
EG_93Civic's Avatar
i think i might clear with the fiber image, i'm also planning to get that hood too, but i think it goes for around $500-600
Old Sep 4, 2003 | 12:32 PM
Hrmmm...thanks
Well if it's my only option, I'll pay it.
I will never cut a giant hole in my hood.
Old Sep 4, 2003 | 01:50 PM
kranked91dx's Avatar
Default Re: (Bryson)
sorry to have to add that, but, mayby a hood with a dragon nose will help,
I know, I know, it'll look like ****, but that is the only thing i can think about right now... ya know the ZC hood will give you a slight more clearance on the timing belt side... other that that....
Hope this helped out a bit
Kranked
Old Sep 4, 2003 | 01:55 PM
EP3_05's Avatar
I think it will fit. The SiR hood has the bumped center section which looks like it would give you the clearance you need. Oh by the way that is one badass setup
Old Sep 4, 2003 | 03:02 PM
RCautoworks's Avatar
Default Re: SIR hood....does it add under hood clearance?...how much? (91civic)
Well if your thinking of ordering a carbon fiber hood, if your looking at Fiber Images hoods you should read this first. It talks about the underneath of the hood. Its a good write up about the styles of there hood now.
https://honda-tech.com/zerothread?id=572161
Old Sep 4, 2003 | 03:07 PM
Jared's Avatar
Default Re: SIR hood....does it add under hood clearance?...how much? (90blackcrx)
mb products makes a fiberglass hood skin for the 88-91 that would clear, butit requires hood pins on all four corner.
Old Sep 4, 2003 | 03:11 PM
HONDABOND's Avatar
Wasup Bryson, always a plesure to see your ZC (SethZC )
Old Sep 4, 2003 | 03:36 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I have a carbonfiber SiR hood on my CRX.
It does give you more room. I just went and checked my hood, and if you cut the under hood stuff, it seems like you would have plenty of room for the manifold.
If you could meassure how high the manifold sticks up, I could meassure mine and
give you some idea of how much room it gives.
Take a pic with a ruler next to it or something like that. Don't use the valve cover as a guide since it changes from car to car.
Old Sep 4, 2003 | 10:33 PM
SpeedApex's Avatar
I am having the same problems with hood clearance. I found a place here that will make a custom carbonfiber hood. They are going to make it to clear my motor and turbo. I will let you know how it turns out if you are interested.
Old Sep 4, 2003 | 11:43 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: SIR hood....does it add under hood clearance?...how much? (SpeedApex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedApex &raquo;</TD></TR><TR><TD CLASS="quote">I am having the same problems with hood clearance. I found a place here that will make a custom carbonfiber hood. They are going to make it to clear my motor and turbo. I will let you know how it turns out if you are interested.
that is gunna be FAST
Old Sep 5, 2003 | 06:40 AM
JDMCRX's Avatar
My 89 CRX with the SiR front end with the b16a and place racing motor mounts i could stick a spray can cap ontop of the valve cover and it cleared there is about 1.25" to 2.25" more clearence that manifold would clear noprob the nose of the hood is bumped up too alot
Old Sep 5, 2003 | 09:36 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
Damn... everytime I see that Rex I love it more and more. haha... wow. You are absolutely insane, but you're the man!
Old Sep 5, 2003 | 10:01 AM
Project91CRX's Avatar
Default Re: (HONDABOND)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND &raquo;</TD></TR><TR><TD CLASS="quote">Wasup Bryson, always a plesure to see your ZC (SethZC )</TD></TR></TABLE>
Same here ... well.. bet both of you guys can already tell by my name.
Old Sep 5, 2003 | 10:18 AM
kaoticstyles's Avatar
whered you get the manifold made and how much was it that is a nice manifold
and that crx is =o
Old Sep 5, 2003 | 10:47 AM
For you guy's that specified that you had the SIR carbon hood...what manufacture is it from?
I'm going to do a little more research about the Fiber Images hood, and if all looks good, that's what I'm gonna go with.
Oh, hey Seth and Project!
Old Sep 5, 2003 | 12:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">For you guy's that specified that you had the SIR carbon hood...what manufacture is it from?
Oh, hey Seth and Project! </TD></TR></TABLE>
Did you read that write up I posted ?
Old Sep 5, 2003 | 01:05 PM
I did look at some of the pages...which page has info on the Fiber images hood? So far all I've seen is VIS, VIS, VIS...ect
I've got shitty 56K so it takes forever.
Old Sep 5, 2003 | 01:41 PM
O sorry, I think its all about VIS.
Old Sep 5, 2003 | 03:45 PM
EG8R's Avatar
Default Re: SIR hood....does it add under hood clearance?...how much? (ThE bEe GuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote">
that is gunna be FAST</TD></TR></TABLE>
What makes you think that???
Old Sep 5, 2003 | 04:46 PM
SpeedApex's Avatar
I hope it will be pretty quick. I want a full-race manifold that is designed like the b series manifolds. I can't go far enough forward to used the full race manifold that they have for the h22.
Old Sep 5, 2003 | 05:52 PM
MidoriEK4's Avatar
here is my 2 cents. i have a FI hood but not the SiR one. the clearance in the back is a lot more than stock but where it comes down and folds in the front by the bumper you have almost the same clearance as a stock hood. thats my info
DaN
Old Sep 5, 2003 | 07:28 PM
warrick's Avatar
if you wanted to hack your hood and put a carbon fiber duct/cowl, that might give you clearance and cooling... a guy I know here with an h22 and custom turbo manifold had to hack his cf hood because his engine bay was just too hot... turbo sits close to the hood, not down below. anyway, he hacked it up and is getting (or may already have) a vent from http://www.carbontrix.com . just a thought.
Old Sep 5, 2003 | 09:07 PM
Ef Whore's Avatar
Must be nice to have dough.....ILL setup you have there.
