Installing a short shifter today... tools needed?
Hey guys Im installing a short shifter today into my 94 hatchback. What tools will I need to get this done. The car will be jacked up on stands. Also does any part of the short shifter need to be greased at all. Thanks alot guys
Drew
Drew
From: I told you to wait in the truck in Texas, United States
This is a CRX so I am not sure if yours is the same
Ratchet,extension 10mm socket 12mm wrench and socket..
Take out bolts in the order they are numbered,grease all the parts that move.
if pic does not work click here.
might want to throw in some stainless steel washers in bewteen the forks and the bottom-ball of the shifter (if there is room). If there is a lot of room (or if its wiggle-able) then its going to rattle and drive you crazy
