homemade turbo kit need help ( manifold)
Old Sep 4, 2003 | 07:07 AM
vtecmissle's Avatar
Default homemade turbo kit need help ( manifold)
i am trying to put together a cheap turbo kit . used t3 turbo from thunderbird and am looking at fitting a manifold (obx or boost ) i know the obx isnt supposed to be great but at 200 dollars is all i can afford. ( 225 with downpipe on ebay)is the t3 turbo 4 bolt of 5 bolt and what other manifold options do i have for this manifold. i might source one used. thanks.
Old Sep 4, 2003 | 02:19 PM
DA-MAX's Avatar
Default Re: homemade turbo kit need help (vtecmissle)
the money you save buying the OBX will be negated when you have to spend money later getting all the cracks repaired...just save up $75-100 or some more bucks up and buy a quality one first time around...
Old Sep 4, 2003 | 02:34 PM
DigitalFusion's Avatar
Default Re: homemade turbo kit need help (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">the money you save buying the OBX will be negated when you have to spend money later getting all the cracks repaired...just save up $75-100 or some more bucks up and buy a quality one first time around...</TD></TR></TABLE>
exactly... try a lovfab log style mani... lovefab.com
Old Sep 4, 2003 | 04:32 PM
DA-MAX's Avatar
Default Re: homemade turbo kit need help (CustomCockpits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CustomCockpits &raquo;</TD></TR><TR><TD CLASS="quote"> exactly... try a lovfab log style mani... lovefab.com</TD></TR></TABLE>
thats the way I'm going hopefully next month!!
Old Sep 4, 2003 | 04:45 PM
arjusmc's Avatar
the turbo is 5 bolt, get a used mani if you want to save some $
Old Sep 16, 2003 | 07:32 PM
BuddyLee's Avatar
Default Re: homemade turbo kit need help (arjusmc)
im doing the same thing....
i was patient for a few months, and i found a homemade one for 60 bucks.
you could get on mcmaster.com and buy the parts you need if you have a friend that can weld. It would cost you about 60-80 bucks or so.
GTEC913
Dec 17, 2007 01:39 PM
AlxSiR7
Jun 16, 2005 04:37 PM
hotimportcrx
Feb 18, 2005 08:18 PM
JDMflavor_EJ
Nov 13, 2004 02:37 PM
