my under powered gsr build predictions (dyno on friday)
Old Sep 3, 2003 | 09:11 PM
NW94RS
Guest
Posts: n/a
Default my under powered gsr build predictions (dyno on friday)
here goes this is a gsr motor basically a street build hoping to pull mid 190s I'm worried about a good midrange rather than peek numbers.
some of the parts were unnecessary but they needed to be replaced so I just went with the type R part number.
HEAD
port and polished
valve job
milled
toda A's
type R valves
type R valve springs
type R rocker arms
type R distributor
type R retainers
jdm 4-1 header (modified)
skank 2 manifold & 68mm tb (portmatched)
type R intake arm
monster air filter
hondata i/m gasket
BLOCK
toda oil pump drive
jdm ITR pistons
2 layer head gasket
MISCELLANEOUS ****
hondata s200
j+s safe guard
ARP head studs
ARP rod bolts
TRANNY
jdm lsd 4.785
toda fly wheel
act street strip
the motor is going in a 1994 acura integra it weighs about 2100 pounds w/out driver looking for 13's on slicks give me some input what do you think I'll lay down.
I will update when car hits the dyno.
Old Sep 3, 2003 | 10:00 PM
98itR484's Avatar
Default Re: my under powered gsr build predictions (DC-2R)
190's should be no problem, with that set up....especially if you upgrade the header
i hit 187 on a stock ITR motor, with just a SMS header.
Old Sep 4, 2003 | 04:38 AM
stick's Avatar
with ur milled head, higher compression pistons, Toda A's, port and polish u should be well up to 200hp or more. of course some good tuning too.
u didnt mention what type of exhaust.
i think low 13's is possible w/ DR or slicks.
Old Sep 4, 2003 | 05:59 AM
stupidfast's Avatar
Default Re: my under powered gsr build predictions (stick)
I say 195 to 205whp if tuned properly and high 12s easy with good driver and slicks.. Hope you are lucky enough to see those numbers.
Old Sep 4, 2003 | 01:19 PM
Status Sean's Avatar
Default Re: my under powered gsr build predictions (stupidfast)
sean edwards you are so cool
Old Sep 4, 2003 | 02:11 PM
obd2gsr's Avatar
190 hp.
Old Sep 4, 2003 | 04:12 PM
bossman032's Avatar
Default Re: my under powered gsr build predictions (obd2gsr)
let us know!!!
Old Sep 4, 2003 | 04:17 PM
GreenR's Avatar
185-195
Old Sep 4, 2003 | 04:29 PM
hybridEj6's Avatar
Default Re: my under powered gsr build predictions (GreenR)
i say 195-200 tuned well, how did you get your integra to be 2100 pounds?
Old Sep 4, 2003 | 11:30 PM
NW94RS
Guest
Posts: n/a
Default Re: my under powered gsr build predictions (ekhybrd)
It's an rs and it weighed 2440 w/ 5 lug and a full tank and full interior and air bags
now I have a
c/f hood
light weight battery
gutted
fal rear glass
no air bags
no ac or ps
thats about it
oh yeah 11' w. type r caliper 4 lug
Old Sep 5, 2003 | 10:16 AM
slowdx's Avatar
192.7534823 HP
Old Sep 12, 2003 | 03:02 PM
obd2gsr's Avatar
it's friday
Old Sep 26, 2003 | 08:52 AM
DC-2R_SUCKS's Avatar
Probably about 125hp with that POS...
Old Sep 26, 2003 | 09:02 AM
GokuSSJ4's Avatar
some peeps have hit around 200whp with a similar set up , reme,ber that tuning is the key .
Old Sep 26, 2003 | 10:11 AM
All Motor Rex's Avatar
190s shouldn't be a problem at all. You should make over 200.
I had a similair set up on my old motor, except no hondata and only had itr cams. I made a little over 200whp
Keep us posted.
Old Sep 26, 2003 | 10:23 AM
MaxBoost's Avatar
New User
Default Re: my under powered gsr build predictions (All Motor Rex)
I predict 185-189whp.
cyber gook
161
Jul 19, 2009 02:26 AM
mtmetzger
Jun 10, 2007 06:26 PM
mtmetzger
Jun 8, 2007 09:21 AM
JEHDEEM
Oct 6, 2004 11:22 PM
N~FaMouSKhMerBoi
Nov 5, 2002 08:27 PM
