Just swaped B16A into CRX HF and engine has knockings...?
Old Sep 3, 2003 | 08:24 PM
92h22a4's Avatar
Default Just swaped B16A into CRX HF and engine has knockings...?
Me and a budy has just finished swaping a B16A into his HF CRX. It starts and sounds like a strong motor, but there is a constant loud knocking from inside of the engine. It is near the timing belt.
Is the motor bad?
Any help would be appreciated fast...geting headaches.
Old Sep 3, 2003 | 09:16 PM
sleeper4dr's Avatar
Default Re: Just swaped B16A into CRX HF and engine has knockings...? (92h22a4)
if you can hear the noise with the hood closed or from inside the car then something sounds very wrong to me. i would guess you have a bad rod bearing.
Old Sep 3, 2003 | 11:01 PM
MisterB's Avatar
Default Re: Just swaped B16A into CRX HF and engine has knockings...? (sleeper4dr)
Is it a knocking or a loud ticking?
If it is coming from the head it could possibly be the LMA (lost motion assembly)
These have a tendancy of going bad when running bigger cams or if the motor has sat for a long period of time.
Old Sep 4, 2003 | 06:23 AM
RexB16's Avatar
Default Re: Just swaped B16A into CRX HF and engine has knockings...? (MisterB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MisterB &raquo;</TD></TR><TR><TD CLASS="quote">Is it a knocking or a loud ticking?
you will ALWAYS hear clicking from a gen 1 b16, sounds just like a typewriter. it's usually the LMA's, but not really due to running bigger cams, rather, its simply the case that these motors are 14-15 years old by now.
Old Sep 4, 2003 | 08:53 AM
92h22a4's Avatar
Default Re: Just swaped B16A into CRX HF and engine has knockings...? (RexB16)
No guys, It sounds as if someone was hitting the head near the timing belt with a hammer from the inside. I know what the valve ticks sound like and that's not it. The knocking is loud and it's only at idle speed. No reving at all (too scared to reve).
Anyone know what can we do?
Old Sep 4, 2003 | 09:32 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
I hope you've got 93 or 91 octane in there. Sounds like you've got a terrible knock. Is the check engine light coming on after warmup? If so it's prolly throwing a code 23... knock sensor. Tell us where you got the swap from.
Old Sep 4, 2003 | 09:39 AM
roadawg's Avatar
Default Re: (VashTheStampede)
That's what I was wondering, where he got the motor from.
Old Sep 4, 2003 | 10:30 AM
SiB16A's Avatar
Default Re: (SiRWanabe)
yea where did you get your motor from...because ill make sure i wont order any thing from them. thanks
Old Sep 4, 2003 | 11:48 AM
MisterB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexB16 &raquo;</TD></TR><TR><TD CLASS="quote">
you will ALWAYS hear clicking from a gen 1 b16, sounds just like a typewriter. it's usually the LMA's, but not really due to running bigger cams, rather, its simply the case that these motors are 14-15 years old by now.</TD></TR></TABLE>
Not true... i have a 1st gen with itr lma and correctly adjusted valves and i hear absolutly no ticking. It did not start ticking until after i put in the cams. so i replaced the lma and no more noise.
Old Sep 4, 2003 | 12:00 PM
civickiller's Avatar
rod bearing, i bought a b18a from a guy, put it in, started it up, loud tapping sound acutally not a tap a loud banging sound, u could hear it over my open header, so took the bottom end apart, #1 and 3 rod bearings were gone, 3main bearings gone, crank no good, 2 rods bent.
i recommend taking yoru oil pan off and inspecting every rod by tring to shake it up and down and front to back and see if it moves, it there alot of play, u know its a rod bearing. but dont start it up again before u do serious damage if there already isnt serious damage
Old Sep 4, 2003 | 01:48 PM
92h22a4's Avatar
Default Re: Just swaped B16A into CRX HF and engine has knockings...? (civickiller)
We got the motor from http://www.hmotorsonline.com
I was the person that installed it. We took it off the crate and everything. Wiring complete, and double checked. Only wire left that is not wired was the data link wire. That doesn't matter any way. It was an OBD-0 to OBD-1 conversion.
Oh well, I guess he'll have to tear down the engine and check. Thanks for advising. Wish us luck on getting it fixed.
Old Sep 4, 2003 | 04:42 PM
Hold on a sec... if it's HMO they're REALLY good about **** like that. Call em up, ask them some questions... they're great guys! I'm sure that if you have a MAJOR prob like that they'll fix it. I got a bad knock sensor on my swap, and they just shipped me a new one right away. Awesome guys. Call them ASAP! You won't regret it!
Old Sep 4, 2003 | 07:32 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">Hold on a sec... if it's HMO they're REALLY good about **** like that. Call em up, ask them some questions... they're great guys! I'm sure that if you have a MAJOR prob like that they'll fix it. I got a bad knock sensor on my swap, and they just shipped me a new one right away. Awesome guys. Call them ASAP! You won't regret it!</TD></TR></TABLE>
good point call them before tearing it apart so that you dont void the warranty (in case they have a rule like that).
Old Sep 5, 2003 | 03:24 PM
92h22a4's Avatar
Default Re: (keebler65)
Yeah, I heard they are really great. That's why he got it from them. I'll make him call them and see what's up.
Old Sep 5, 2003 | 09:08 PM
bossman032's Avatar
Default Re: (92h22a4)
nearly all high mileage motors KNOCK!!!!
even accords 90-92
Old Sep 5, 2003 | 09:13 PM
Ef Whore's Avatar
Default Re: (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">nearly all high mileage motors KNOCK!!!!
even accords 90-92</TD></TR></TABLE>
Not true at all; something has to be bad internally to cause a knock.....Ive seen many a b16 swap and they all sounded smooth as butter after a proper valve adjustment.
Old Sep 5, 2003 | 10:04 PM
bossman032's Avatar
Default Re: (Ef *****)
I ment the valves knock need adjustment sloves the problem most of the time!!!! Mostly High Mileage Motors!!!
the_real_paper_shredder
Dec 20, 2009 06:23 AM
jeezyskillz
Jan 18, 2007 09:34 PM
hondacrx92
Apr 16, 2006 09:51 AM
iriefly
Jun 7, 2002 10:29 AM
ososlow
Mar 6, 2002 05:46 AM
