direct turbine fuel injection???
Old Sep 3, 2003 | 07:11 PM
JeremyL's Avatar
Default direct turbine fuel injection???
i dont know if this is the correct term for it but i heard of some tractor pull tuners using a system of injection where you have fuel injectors that spray fuel directly into the turbochargers turbine housing to basically cause combustion right in the turbine to produce instant full boost pretty much off idle
does anyone know of any type of process like this?
Old Sep 3, 2003 | 07:17 PM
BoOsTeD_eK's Avatar
Default Re: direct turbine fuel injection??? (JeremyL)
thats sort of how jet engines work.
Old Sep 3, 2003 | 07:27 PM
nigel's Avatar
try it.. if you send chunks of turbo through your hood we know it dont work on hondas. sounds like a great idear!
Old Sep 3, 2003 | 08:48 PM
Full-Race Javier's Avatar
sounds like some type of anti lag system. most systems generate extremely hot gas temps and turbo/mani temps. do it to much, and the turbine/housing will fail sooner.
axial flow gas turbine engine diagram....(turbos are radial flow)
a turbo analyzed
http://gypsy.cad.gatech.edu/co...oup03
just search for radial flow gas turbines and axial flow gas turbines
Old Sep 3, 2003 | 10:37 PM
GSRswapandslow
Guest
Posts: n/a
that is anti lag
the other way is to retard like ****
either way, egt;s would be toooo damned high...and you'll blow your **** if you do it often,
it's really a lot more complicated than ppl think...and not something to play around with
Old Sep 4, 2003 | 03:20 PM
JeremyL's Avatar
Default Re: (GSRswapandslow)
well im sure it would be a very intracite setup and certainly not streetable for a car and would take a very seriously built turbine housing to handle that type of heat
Old Sep 4, 2003 | 03:37 PM
boosted92's Avatar
Default Re: (JeremyL)
You're probably thinking of anti-lag. Your ECU dumps in a ton of fuel and cuts back timing a lot, which dumps a lot of un-burnt fuel into the header where it ignites and creates a ton of exhaust heat, spooling the turbo.
Old Sep 4, 2003 | 05:17 PM
fsp31's Avatar
Default Re: (boosted92)
WRC cars utilize this type of system for anti-lag. Of course, one of their turbos cost more than a brand new S2000... but's that's really a bargain compared to those $500,000 tranny's.
Old Sep 4, 2003 | 05:21 PM
MADEINIRAQ's Avatar
Default Re: (fsp31)
the misfiring system is superior.
nightshift
Honda Civic (2006 - 2015)
31
Jun 3, 2009 11:02 AM
crxricer66
Oct 18, 2007 04:11 AM
SIXPAK GQ
Jul 22, 2007 12:00 PM
OSIRIuS23
Dec 30, 2005 07:44 AM
JrCRXHF
Aug 23, 2003 10:05 PM
