motor mounts
i have a new project on the go and am wondering what engine mounts do i need in order to put a 1st gen b16a into a 1990 civic any help would be appreciated
i would suggest hasport linkage and mounts, get the linkage from whatever mount company you buy, they all place the engine a little diff. also i dont like the place racing places the engine a litting two far forward, sometimes causing axles to rub, esp if you get larger dia. axles like raxles, seen this problem more than once. hope this helps you avoid any future problems.
Hey man i put a bunch of B16A in 88-91 civic's and CRX's i found the best mounts are place racing mounts if u are doing NA but if u are doing Turbo Hasport. Place Racing Mounts u can use 90-93 axles they bolt right in VS has sport u have to use 86-89 inner tegs and 90-93 outers so if u break a axle on the side of the road good luck. i like the place never had one prob did 6 or 7 swaps with not one prob at all they fit no banging nothing. Just had to notch the front cross member. And the idle is not ruff.
Pikachu
Dec 17, 2006 08:31 AM
Rratedcivichatch
Jan 2, 2003 03:51 PM
