Rebuilt motor won't start !!! Have spark and fuel NEED HELP!!!!!
Old Sep 3, 2003 | 03:46 PM
boosted_zc's Avatar
Default Rebuilt motor won't start !!! Have spark and fuel NEED HELP!!!!!
Like it says, fully rebuilt ZC. It has fuel and it has spark. It sounds very odd because it's not even trying to fire. All i hear is the whine of the starter and that's it. What the heck is going on. I just got a brand new main relay so that's not it. Any help would be greatly appreciated. Thanks
Old Sep 3, 2003 | 05:15 PM
sporkcrx's Avatar
Default Re: Rebuilt motor won't start !!! Have spark and fuel NEED HELP!!!!! (boosted_zc)
How did you check for fuel? How did you check for spark?
Old Sep 3, 2003 | 06:13 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_zc &raquo;</TD></TR><TR><TD CLASS="quote">Like it says, fully rebuilt ZC. It has fuel and it has spark. It sounds very odd because it's not even trying to fire. All i hear is the whine of the starter and that's it. What the heck is going on. I just got a brand new main relay so that's not it. Any help would be greatly appreciated. Thanks</TD></TR></TABLE>
You need 3 things for a car to run ... fuel / spark / air
You say you have fuel ... but have you actually checked fuel pressure? You should do that to be sure that you have the proper amount.
As far as spark ... is it a good spark? You can have spark and it is weak and will not start. You should have a nice bright yellowish color in the spark when checking it.
Old Sep 3, 2003 | 06:34 PM
I8ayellowcrayon's Avatar
Actually its 4 things it takes for an engine to run. Air/fuel, spark, compression, and timing. I had the exact same problem you had, and my timing was out 180*. Take of your distributor and turn the little gear 1/2 a turn and try it again.
Old Sep 3, 2003 | 06:38 PM
photonjedi808's Avatar
Default Re: (I8ayellowcrayon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">Actually its 4 things it takes for an engine to run. Air/fuel, spark, compression, and timing. I had the exact same problem you had, and my timing was out 180*. Take of your distributor and turn the little gear 1/2 a turn and try it again. </TD></TR></TABLE>
How did you fit the dist in? It shouldn't even fit with the timing off 180*.
Old Sep 3, 2003 | 06:52 PM
well that could be another thing, I had SOHC D15B7. I have no clue about DOHC dizzy's. My bad.
Old Sep 3, 2003 | 06:53 PM
Bah, I'm retarded. I didn't turn the dizzy itself over, just the gear thing inside of it.
Old Sep 3, 2003 | 08:13 PM
boosted_zc's Avatar
Argh, i'm a dumbass. I just forgot to adjust my cams when i put the head back together, none of the valves were seating, therefore no compression. I did a little ghetto job on it because i don't have a feeler gauge, but it started right up. Tomorrow i'll go get a feeler gauge and do it to spec. Thanks anyway for all of the info guys.
Jay
eg5
Feb 27, 2012 03:41 PM
bri1998
Jan 8, 2008 09:18 PM
ghostcivic
Jan 16, 2007 02:46 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
