Using the F23 harness, what has to be extended in a H22 swap?
there is quite a few cant remember wich exactly but when you get the harness off and start matching thing up then you will see wich ones need extending, also if your using usdm and depending on year you will have to wire up the external coil my was a 99 so i had to do it
