Help...Are G2 Integra OEM cats the same between the 1990/1991 vs. the 1992/1993?
Old Aug 17, 2001 | 07:14 PM
erasure2's Avatar
New User
Default Help...Are G2 Integra OEM cats the same between the 1990/1991 vs. the 1992/1993?
Hello all,
I am interested in finding out if the 1990-1991 Integra OEM catalytic converter is the same as the 1992-1993 cat?
I have noticed that the 1990-1991 exhaust is shorter than the 1992-1993 exhaust, so I was wondering if the cats are different?
I may need a cat and I have a 1990 so I was wondering if I can use a 1992-1993 cat.
Thanks in advance for you help,
e2
Old Aug 17, 2001 | 08:23 PM
DB2-R81's Avatar
25 Year Member
Default Re: Help...Are G2 Integra OEM cats the same between the 1990/1991 vs. the 1992/1993? (erasure2)
The 92 -93 cat is about 3 inches longer as you suspected.
Old Aug 17, 2001 | 09:23 PM
Vracer111's Avatar
Have you priced the Cat's from Acura dealers...$700 -$800 dollars for a 1990-91 integra! Go with an aftermarket performance one, will save you a ton of money (like $400+ dollars!!) Don't think the Cats are different from 90-91 to 92-93, just think the header pipe is longer. When I got my Greddy SP exhaust it came with a short extension section for the header collector before the cat (for 92-93 integras).
[Modified by Vracer111, 10:25 PM 8/17/2001]
Old Aug 18, 2001 | 05:04 AM
erasure2's Avatar
New User
Default Re: Help...Are G2 Integra OEM cats the same between the 1990/1991 vs. the 1992/1993? (Vracer111)
Vracer111 and DB1-R81,
Thanks for the info, but u guys are on opposite sides, lol. Who's right?
Any other peeps with info?
Vracer111...yeah I know aftermarkert cats are an option, but I have seen used OEM cats for well under $50. So I think I can save a bit of $.
Old Aug 18, 2001 | 10:12 AM
Quang's Avatar
New User
DB1-R81, is correct, the 92-93 cat is a little longer than the 90-91. I know this because I bought a gutted out 90-91 cat and it was 2-3 inches shorter than my stock 93 cat.. If anyone is interested in a 90-91 gutted cat, let me know.
todahead
Dec 9, 2014 01:54 PM
Jswift1
Feb 1, 2007 10:37 PM
vr4twinturbo
Nov 27, 2006 06:48 PM
