S2000 parts on RSX motors
Old Sep 3, 2003 | 01:48 PM
-KangaRod-'s Avatar
Default S2000 parts on RSX motors
Hey,
I remember a while ago hearing a vicious rumour that the heads on the F20C and K20A3 motors were pretty similar. Has anyone tried swapping any parts from them (cams, intake manifold, header out the side by the wheel, valve springs?)
Old Sep 3, 2003 | 04:19 PM
Pacman
Guest
Posts: n/a
Default Re: S2000 parts on RSX motors (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">Hey,
I remember a while ago hearing a vicious rumour that the heads on the F20C and K20A3 motors were pretty similar. Has anyone tried swapping any parts from them (cams, intake manifold, header out the side by the wheel, valve springs?)</TD></TR></TABLE>
The cams you can't...The valve springs YES....That is all I know...I'll let you know about the other later when I get more INFO...
Old Sep 3, 2003 | 07:53 PM
f@sth@tch89's Avatar
Compare the 2 head gaskets and see if the bolt pattern is the same. I kinda heard the same rumor.
Old Sep 3, 2003 | 08:31 PM
T4eg's Avatar
Default Re: S2000 parts on RSX motors (fasthatch89)
I have heard the S2K head bolts onto the RSX...not 100% positive
Old Sep 5, 2003 | 06:41 AM
-KangaRod-'s Avatar
exactly. I've also heard unconfermed rumors of this...
I guess the motors are really too new to be sure. What head would you rather have on your car? the F20C flows better, but the A3 head has VTC.
Old Sep 5, 2003 | 07:25 AM
x00gsr's Avatar
Dayem I like to see a s2k head on a crv (k24) block.
Old Sep 5, 2003 | 10:42 AM
H22ek4's Avatar
Default Re: (x00gsr)
how about k20 tranny mated to the f20c.
Old Sep 5, 2003 | 01:07 PM
C_A_T's Avatar
The dimensions on the heads are amazingly close. Some top end parts will interchange.
However, there isn't much point in swapping a K20A/A2 head for the F20C head. While the F20C head flows 5-10% better, both are worlds beyond a B-series to begin with. And the F20C head flows better in part due to its larger valves (1mm bigger). With very little work the K20A/A2 head will match the F20C head in flow and you get to keep the VTC.
C_A_T
Old Sep 5, 2003 | 08:08 PM
TECH43 RACING INC.'s Avatar
Default Re: (H22ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22ek4 &raquo;</TD></TR><TR><TD CLASS="quote">how about k20 tranny mated to the f20c.
this pic is bullshit...its been photoshopped. its from "prototype" they have a lotus elige with a k20r. they said they might cast a new bell housing to make it fit, but i doubt it.
Old Sep 6, 2003 | 05:23 AM
-KangaRod-'s Avatar
Default Re: (TECH43 RACING INC.)
yeah, i looks sorta photochopped right where the bell housing meets the block. It still would be cool though. Although I like the K20 heads better than the F20 heads, mainly due to VTC!
turbociv910
Aug 11, 2009 12:35 PM
nahonda04
Honda S2000
Jan 14, 2009 06:50 PM
jorge89
Jun 27, 2008 03:58 PM
EduardoDC5
Dec 13, 2007 02:55 PM
ZTYPE_S
Feb 25, 2004 01:16 PM
