LS/VTEC HELP!!!!
I am currently building an LS/VTEC motor. I wanna build it right so heres what i have in mind.
- 1996 Integra LS Block
- 1990 b16a Head
- P28 ecu w/ skunk 2 chip
- Block Decked and Honed
- LS Rods Shotpeened for strength
- ARP Rod Bolts
- ARP Head Bolts
- ARP Main Bolts
- Integra type-r cams
- Integra type-r/crower/endyn valve springs
- Integra type-r/crower/endyn retainers
- Integra type-r intake manifold
- Type-r pistons
anyother suggestions on how i can make it stronger?? I don't want any problems!!
- 1990 b16a Head
- ARP Rod Bolts
- ARP Head Bolts
- ARP Main Bolts
- Type-r pistons
how outta control is your driving?
If you rev to 9000 every day you might want to think about a girdle.
Definitely swap the oil pump, water pump, timing belt, and main seal while you got the engine out of the car. Make sure you use VTEC parts of course.
i would also go with over sized pistons as well (81.25) just to make sure you have a completely true cylinder wall. i didnt when i put mine togther with PR3's and now im running in to problems with pistons that are not true to my bore. but as they say what doesnt kill you only makes you stronger...(OS CTR's are in the mail
your set up is almost the same as mine, vtec oil pump and water pump with belt is key also. you should be very happy, i am
-sander
)your set up is almost the same as mine, vtec oil pump and water pump with belt is key also. you should be very happy, i am
-sander
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">peruse the thread in my signature, you will gain priceless insight into what helps/hurts the ls/vtec.</TD></TR></TABLE>
good thread!
good thread!
Thanks man.........my bros LS/VTEC just blew so i have decided to go aginst it. i am officially goin to go LS Turbo. thanx to all who have tried helpin me
how did he "blow" the motor what broke ?
and in doing an ls turbo doesnt mean it wont "blow" pesonally id trust an lsvtec over ls turbo PLUS an lsvtec spec'ed out as listed would out run the turbo (unless you tune it right and keep it that way :/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">peruse the thread in my signature, you will gain priceless insight into what helps/hurts the ls/vtec.</TD></TR></TABLE>after reading this thread it changed my mind and gave me alot of info on Ls/vtec and i choosen to take the Ls/vtec path now ...i say read it ...even if your still not goin to go Ls/vtec is a very informative thread...
