questions on installing oem body kit
Old Aug 17, 2001 | 04:50 PM
Flamenco-T's Avatar
Default questions on installing oem body kit
anyone got the instruction that came with it ?
if so will you fax it to 801-730-4857, and I can paypal you the cost to fax it (long distance and all) ??
how do I take off the stock side skirt ? and which bolts goes where and etc..?
thanks
[Modified by flamenco, 5:51 PM 8/17/2001]
Old Aug 17, 2001 | 07:23 PM
ssblue's Avatar
Default Re: questions on installing oem body kit (flamenco)
i don't think you really need the instructions except maybe for the drilling for the rear skirts...once you pull off all the bolts holding the side skirts on, just grab it and pull it towards the back of the car to unhook it and it will come right off...hth
Old Aug 17, 2001 | 07:43 PM
2005 TSX's Avatar
Default Ok...
First of all, what instructions do you need? For the front, sides, rear? I think I have the instructions for the rear installation. The sides and front should be pretty easy to install without instructions.
The stock sides are really easy to take off. First, you have to unscrew the plastic screws that are at the bottom of the stock side skirt. Then you kind of have to push the whole side skirt toward the front (or back, sorry I can't remeber!) of the car. Take your time, there is no hurry. At first you think it is going to break, but it will come off. There will be white plastic clips that are still attached to side of the car, that were holding the side skirt on. I forgot how to take those out, but I think you have to twist a little and pull them out. Then you put those plastic pieces on to the new side skirt. Take the side skirt and align the plastic things into the holes that they came out of. Make sure everything is properly aligned! The new skirt should just pop in. Just put the plastic screws back into the bottom of the new side skirt.
If you need any more help, or would like the instructions for the rear, just e-mail me at joshua_marks@hotmail.com
Hope I could help!
[Modified by 2001 Integra GSR, 8:44 PM 8/17/2001]
Old Aug 17, 2001 | 07:56 PM
Flamenco-T's Avatar
Default Re: Ok... (2001 Integra GSR)
I need the rear, particualry where to drill and etc...
thanks
Old Aug 17, 2001 | 07:58 PM
2005 TSX's Avatar
Default Ok...
I can e-mail you the instructions if you would like, in picture format. Is that ok?
Old Aug 17, 2001 | 07:59 PM
Flamenco-T's Avatar
yes please..
thank you.
arsumirat@hotmail.com
agaign , thanks
Old Aug 17, 2001 | 11:17 PM
2005 TSX's Avatar
Default You've got mail.
flamenco, check your hotmail. I sent you photos of the document. If there is any problem, I can try posting them on my web site, or try faxing them to you. I have a fax machine at work, so the earliest I would be able to get them to you is Monday morning (PST). Hope everything works out for you.
Old Aug 18, 2001 | 01:11 PM
Flamenco-T's Avatar
Default Re: You've got mail. (2001 Integra GSR)
I have got it..
thanks
Old Aug 18, 2001 | 10:30 PM
2005 TSX's Avatar
Default Sure...
Anytime!
Old Aug 19, 2001 | 12:32 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Sure... (2001 Integra GSR)
Stan if you need help give me call.
art
boost fed ls
May 3, 2004 05:36 PM
Comptech98GSR
Jul 3, 2002 08:29 AM
yellowbuffalo
Jun 13, 2002 04:02 PM
mikeSONICGSR
Oct 23, 2001 07:17 AM
