which pcv valve and fuel filter for b16?
Old Sep 3, 2003 | 09:15 AM
NINJASPY's Avatar
Default which pcv valve and fuel filter for b16?
which pcv valve and fuel filter do I need for b16? where would the fuel filter be located at? and what spark plugs should I use?
Old Sep 3, 2003 | 09:24 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: which pcv valve and fuel filter for b16? (NINJASPY)
Pcv valve 17130-PM6-G01 '94 - del sol
Spark plug NGK BKR6E-N-11
Use the Stock filter for your car which is
usually located on the passenger side firewall.
Old Sep 3, 2003 | 09:46 AM
NINJASPY's Avatar
Default Re: which pcv valve and fuel filter for b16? (88DXCRX)
on ngk's website " BKR6E-11 2756 0.052 "
gapped at 0.052, while some suggest 0.044
what gap should I run for a b16 with only ctr cams and i/h/e?
Old Sep 3, 2003 | 12:58 PM
NINJASPY's Avatar
top
Old Sep 3, 2003 | 01:15 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASPY &raquo;</TD></TR><TR><TD CLASS="quote">on ngk's website " BKR6E-11 2756 0.052 "
what gap should I run for a b16 with only ctr cams and i/h/e?</TD></TR></TABLE>
Run the recommend gap that Honda tells you to, which is .039- .043in
Old Sep 4, 2003 | 11:15 AM
88DXCRX's Avatar
Default Re: which pcv valve and fuel filter for b16? (90blackcrx)
You should get NGK stock number 5724.
They are pre-gapped at .043 in.
Old Sep 4, 2003 | 11:29 AM
NINJASPY's Avatar
should? I need reasons why, not just a "should" that doesnt explain anything.... I am running the wrong spark plugs now because what someone told me what I "should get"
Old Sep 4, 2003 | 11:49 AM
88DXCRX's Avatar
see below:
Modified by 88DXCRX at 6:58 PM 3/14/2005
Old Mar 14, 2005 | 03:27 PM
Thagreybomber's Avatar
bump....cause I was looking for this for a long time
Old Mar 14, 2005 | 03:57 PM
88DXCRX's Avatar
Default Re: which pcv valve and fuel filter for b16? (Thagreybomber)
look in the FAQ section..
also see: https://honda-tech.com/zerothread?id=1024595
KevinEJ6__17
Jul 6, 2014 01:55 AM
vladd
Sep 14, 2012 07:00 PM
hnp5
Jan 18, 2006 02:39 PM
BigZ88
Dec 3, 2003 05:50 AM
whagkangmakulet
Oct 2, 2001 05:57 PM
