B16a Swap Question?
Old Sep 3, 2003 | 09:04 AM
SiB16A's Avatar
Default B16a Swap Question?
with a B16a can i use 90-93 integra axles...with Stock 90 hb si Hubs?would the axle fit on to the Si hub ..thats my question....and would i need to get integra springs/coilovers since the motor is heavier?
Old Sep 3, 2003 | 09:17 AM
Mr Furball's Avatar
Default Re: B16a Swap Question? (SiB16a)
yes
yes
and
Yes
Old Sep 3, 2003 | 10:09 AM
SiB16A's Avatar
Default Re: B16a Swap Question? (FURBALL B-16)
Nice answering...Thanks Bro a can anyone else back this up?
Old Sep 3, 2003 | 10:31 AM
Phatwhippin_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16a &raquo;</TD></TR><TR><TD CLASS="quote">with a B16a can i use 90-93 integra axles...with Stock 90 hb si Hubs?would the axle fit on to the Si hub ..thats my question....and would i need to get integra springs/coilovers since the motor is heavier?</TD></TR></TABLE>
Yes. And no. You dont need to get Integra Srpings, etc...... actually, the heavier motor (not THAT much more) will help your launch off the line with more weight over the front tires, as opposed to a 160hp D16a motor.....
Old Sep 3, 2003 | 11:05 AM
misfithamster's Avatar
Default Re: B16a Swap Question? (Phatwhippin_CRX)
i was under the impression that with the s1 and j1 tranny you could use the 90-93 integra axles but with the y1 tranny you had to use 1 integra axle and 1 hybrid axle because of the half shaft difference? is that true or false anyone?
Old Sep 3, 2003 | 11:06 AM
Default Re: B16a Swap Question? (misfithamster)
not 100% sure, although I used a 92 teg GSR int. shaft with 90-93 teg axles on a J1.
Pretty sure the Y1 would be ok with a similar setup, although bette rwith a combination of 89/90 half shafts/outer joints
Old Sep 3, 2003 | 11:11 AM
Full-Race Henry's Avatar
yes to the axles and hub question, and no you dont need to get integra springs or coilover.
Old Sep 3, 2003 | 11:25 AM
Mr Furball's Avatar
Default Re: B16a Swap Question? (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan &raquo;</TD></TR><TR><TD CLASS="quote">
yes to the axles and hub question, and no you dont need to get integra springs or coilover.</TD></TR></TABLE>
You don't need to but it would be better
Old Sep 3, 2003 | 11:35 AM
SiB16A's Avatar
damn everyone .....thanks for answerin my question....you guys made it easier lol...thanks again
Old Sep 3, 2003 | 11:39 AM
not really....... its not that much of a difference....just get different springweights for the front if you're THAT worried about it......
but like I said, for drag racing, more weight up front is better anyway, at least for your 60ft times.....
Old Sep 3, 2003 | 11:52 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatwhippin_CRX &raquo;</TD></TR><TR><TD CLASS="quote">but like I said, for drag racing, more weight up front is better anyway, at least for your 60ft times.....</TD></TR></TABLE>
I did not know he said something about DRAG racing. I THINK he asked about interchangeable parts from one car to another.
Old Sep 3, 2003 | 11:57 AM
"and would i need to get integra springs/coilovers since the motor is heavier?"
yes
yes
and
YES.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURBALL B-16 &raquo;</TD></TR><TR><TD CLASS="quote">
I did not know he said something about DRAG racing. I THINK he asked about interchangeable parts from one car to another. </TD></TR></TABLE>
Way to go, I like the big YES in there, although he asked if he NEEDED to use integra springs, NOT if they were interchangeable. If you could read you'd notice I agreed with you for for the first part, but you are wrong about the springs. The drag racing comment was purely academic, and in this case, probably a good bit of info.
So I advise you to back off, bitch.
OWN3D
Modified by Phatwhippin_CRX at 4:14 PM 9/3/2003
Old Sep 3, 2003 | 12:10 PM
Josh717's Avatar
Use the 90-93 int shaft marked sk7 with the trannies then you can use 90-93 teg axles w/o the dust ring
Old Sep 3, 2003 | 12:32 PM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatwhippin_CRX &raquo;</TD></TR><TR><TD CLASS="quote">"and would i need to get integra springs/coilovers since the motor is heavier?"
yes
yes
and
YES.
OWN3D
Modified by Phatwhippin_CRX at 4:14 PM 9/3/2003</TD></TR></TABLE>
Your still not cool,
OWN3ED by badass himself
Old Sep 3, 2003 | 02:26 PM
Never said I was trying to be. Just watch what you say, before you make an *** of yourself....
Old Sep 3, 2003 | 10:11 PM
SiB16A's Avatar
Hey yall...i learn a lot...thanks for all your advices....REALLY ..i appreciate it...we are all here to help each other ........ either if we are noobs or not ..we are just here to get answers...so lets not argue and stick together as an H-T FAMILY hahahahahahahah NOT ..but yeah lets all get along
GTEC913
Feb 9, 2006 10:14 PM
frye-eghatch
May 24, 2005 01:48 PM
pikappaphi
Oct 14, 2003 08:37 PM
ITR632
Apr 21, 2003 01:24 PM
86redcrx
Feb 3, 2003 11:27 AM
