94-97 Accord Headlights
in order to take out and install the new projector, you need to take out the bumper, corner lens and the grill.
if you not sure how to, just run a search at the upper right corner of H-T
you are really gonna regret those. The output on those are very dim. I would suggest the jdm lookalikes with the h4 conversion. But if thats what you like then, here some info. you need to take out the corner lens, bumper lens and the grill before hand. 2 bolts behind each bumper lens(for the bumper brackets), and one bolt on each side, near where the bumper meets the fender. Lift up and off. 5 bolts for each headlight. This website explains it all, and then some. http://www.andrews.edu/~johnso....html
Depending on how skilled you are, takes about 4 hours. I've done it a bunch of times and usually finish in 1-2 hours. Have fun!
