headlight bulb install?
Old Sep 3, 2003 | 08:08 AM
Grimm's Avatar
Default headlight bulb install?
Hey this sounds silly but I was having a hell of a time last night putting in new bulbs. It didn't seem to want to work . There is some arm thing that clasps the bulb then rotates in and slides under something. I dunno, I don't know if I put them in right or not. They work but? Is there any good diagram on how that arm and bulb thing should work?
It's a 96 civic...
It's these stupid delicate parts I hate...
Old Sep 3, 2003 | 08:13 AM
Turbo12acer's Avatar
is this a civic? the thin metal thing thats like a bent up paper clip?
Old Sep 3, 2003 | 08:15 AM
Grimm's Avatar
Default Re: (Turbo12acer)
Oh yea... forgot about that...
Yea exactly the bent paperclip thing...
Old Sep 3, 2003 | 09:32 AM
Grimm's Avatar
Default Re: (Grimm)
ttt
Old Sep 4, 2003 | 06:43 PM
do this. place headlight in. If you look, there should be a screw in the headlight where the Wire thing goes onto. take a philips head screw driver, unscrew it a bit, not to much. Stick the side that is flat under the screw and screw it in kinda tight. Make sure that the part that has teh little U is on bottem. that goes over a plastic part on the headlight. after that it should be set. Connect headlight, place rubber back on. you good to go. If this confuses you, post up a picture of the clip and picture of where the headlight goes into and ill show you in detail. Hope this helps
NOFX
17
Oct 11, 2008 04:25 PM
BrutalDawg
Oct 13, 2007 07:11 PM
Shinbo
Jan 17, 2005 08:13 PM
Nader_D
Jul 24, 2003 12:42 PM
