Bottom line.....what do I need to bring my 1997 Integra GS-R into the 14-14.5 1/4 mile range?
Well you guys, what do you think I need to bring my 97 integra GS-R into the 14-14.5 1/4 mile range? I'm talking about modifications that don't require me to pull my block out of the car either.
on streets, full interior, I'd say Cams and the usual I/H/E will get you mid-low 14's with a good launch. Full interior/street tire times are better, because you can fool yourself and get beat by slower cars at the track. 75shot I/H/E will get you 14 flats on streets, or high 13's easily. HTH, -C
I/H/E with a good spring/shock combo, a decent clutch and good tires should net a 14.4 for an experienced driver...imo
IHE, stronger clutch, lightweight flywheel, and CTR cams. that will have you running 14.5s. You might want to add in a VAFC for a little tuning, as the CTR cams will probably like a slightly different crossover into VTEC than the GSR cams
