is this LSD... or some other kind of tranny....???¿
Old Sep 3, 2003 | 02:25 AM
gumbii's Avatar
Default is this LSD... or some other kind of tranny....???¿
i picked up this trany for uber cheap.... i got it at the jdm engine place so i know it works.... he told me it is a LSD transmission... oh... and its for a H22A... so anyhow... he said that you can tell apart a LSD, and a non-LSD trany from where the axles go... he said the non LSD's have a stick, or a thing that seperates the the axles.... this trany dont have that chet... you can see all the way across... theres a piece of axle that i've been to lazy to take out... i took some pics... what do you guys think.....
is it a LSD...¿ or some other kind of h22a trans... like a ATTS, or TCS one...
Old Sep 3, 2003 | 05:38 AM
bagged89hatch's Avatar
Default Re: is this LSD... or some other kind of tranny....???¿ (gumbii)
yes i have heard that if you can see straight through then it is a lsd. i have a trans that i got with my swap that is lsd its stamped on it and i can see right through it i hope that helps
Old Sep 3, 2003 | 05:40 AM
eg6ajk's Avatar
looks like a stock M2B4 LSD tranny .
Old Sep 3, 2003 | 05:46 AM
advanracing62's Avatar
Default Re: is this LSD... or some other kind of tranny....???¿ (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">looks like a stock M2B4 LSD tranny</TD></TR></TABLE>
yep
Old Sep 3, 2003 | 06:04 AM
MugenGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbii &raquo;</TD></TR><TR><TD CLASS="quote">he said the non LSD's have a stick, or a thing that seperates the the axles.... </TD></TR></TABLE>
true, non lsd trannys have a bar that goes across where the axles goes in
Old Sep 3, 2003 | 07:37 AM
T4eg's Avatar
Default Re: is this LSD... or some other kind of tranny....???¿ (MugenGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR &raquo;</TD></TR><TR><TD CLASS="quote">
true, non lsd trannys have a bar that goes across where the axles goes in</TD></TR></TABLE>
Old Sep 4, 2003 | 07:17 PM
gumbii's Avatar
yay... were installing it right now... i will post pics of it when its done... and i'll get some pics of the old tranny... the housing broke and there is two big o'le holes in it... one on the top.. and one on the bottom... but more that tomorrow...
Old Sep 4, 2003 | 07:19 PM
gumbii's Avatar
one more thing... what car did this come from.... what year, model, type, engine did it come off of....
Old Sep 5, 2003 | 07:05 PM
gumbii's Avatar
nobody knows...? okay... thanks guys...
Old Sep 6, 2003 | 04:36 AM
JDMCRX's Avatar
Default Re: (gumbii)
Question this is for a prelude 2 things.
1 It could be a LSD
2 It could be the LSD version tranny off the SH which has that ATTS or traction control and if it is u have to use the ATTS valve body or it will not work.
Old Sep 6, 2003 | 04:37 AM
JDMCRX's Avatar
Default Re: (JDMCRX)
can u take a pic of were the right axle would go the back of the casing look for bolt holes there it looks in one of the pics that it is a ATTS tranny. If so its junk
Old Sep 6, 2003 | 08:13 PM
gumbii's Avatar
here are the pics you wanted... but what are you talking about...? if it doesnt have the ATTS thing.. the tranny wont work for chet...???
do you need better pics...?
please let me know....
Old Sep 6, 2003 | 08:34 PM
gumbii's Avatar
oh.... and one more thing.... the mechanic is stalling in installing the tranny... he's telling me to buy a new pilot bushing... he said because when he tries to fit the flywheel on the tranny... it has like some kind of play... he wiggles it, and it moves side to side... is it really important...? he said that it is wasted... and on the other 2 flywheels, dont work either... is it that important...¿ he said that its wasted, and it dont have enough meat to work right... is it REALY... that important...????!
Old Sep 7, 2003 | 12:01 AM
TurboCX's Avatar
The mechanic is talking about the pilot bearing, not the pilot bushing. The pilot bearing is located on the flywheel and is is very important to replace. Pilot bearings don't cost much either.
In my opinion, I would also replace the throwout bearing as well. These are just precautions that you can take in order to save yourself problems in the long run(having to pull the tranny out again). Good luck.
Old Sep 8, 2003 | 03:19 AM
gumbii's Avatar
Default Re: (TurboCX)
you guys nailed the m2b4 thing.... and about the pilot bearing... it dont use one... we went to part stores and they dont have one.... we even went to the dealer and they told us that lude/accord MT trannies dont use pilot bearing... its called a pilot bushing... they said that it would take them 4 days to get one, and it would be like 20 bucks for it.... its a little POS piece... nothing too it.... i gave it to my friend that works at mama & papa's transmissions.... he said its like one dolar new.... and check out these pics....
i think this is the bottom of it.....
you know that sensor thing... for the speedo.... i found it inside.... but that part that has the powersteering lines is gone.... and when they did the swap... they bypassed the lines that go into that mechanism... could that have caused this.... do you think they switched transmissions on me....?
so what are your thoughts...? do you think it broke becouse they didnt connect those lines..? do you think they gave me a accord tranny...? i did give them a prelude tranny... i remember when it was running... it would grind to put in 2nd, and 3rd gear.... but that was about at 8000 RPM..... what would cause this...?
Old Sep 8, 2003 | 03:28 AM
1bad-eg's Avatar
Yup, you have an lsd.
Old Sep 8, 2003 | 04:11 AM
gumbii's Avatar
Default Re: is this LSD... or some other kind of tranny....???¿ (1bad-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">Yup, you have an lsd. </TD></TR></TABLE>
WOW!!!.... you answered nothing that i wanted to know.... lol... just kidding... at least i know the pictures work.....
SolAssassin
May 7, 2008 03:13 PM
dragaholic
Jan 20, 2006 05:48 PM
tallblondkid
32
Jul 11, 2004 08:36 AM
FoundryWorks1
May 19, 2004 04:03 AM
