what size injectors?
Old Sep 2, 2003 | 10:31 PM
b18junkie's Avatar
Default what size injectors?
hey guys whats a good size injector for my set up below :
b18c block decked
CTR o/s pistons
ITR valvetrain
GSR head milled
ls rods
polished crank
engine balanced
stock GSR throttle and IM
type r fuel pump
DC 4-1
GReddy SP
running hondata s200
C/R is 12.9:1
thanks
Old Sep 3, 2003 | 12:06 AM
GokuSSJ4's Avatar
Default Re: what size injectors? (b18junkie)
what type of cams do you plan on running ??
Old Sep 3, 2003 | 12:11 PM
b19coupe's Avatar
At least 310's, but you can go as big as you want with Hondata
Old Sep 3, 2003 | 07:29 PM
b18junkie's Avatar
probably going to stick with my R cams for now
Old Sep 3, 2003 | 07:31 PM
mmuller's Avatar
Mad Scientist
Default Re: (b18junkie)
what kind of crank?
290's pushing it, 310's
Old Sep 3, 2003 | 07:57 PM
b18junkie's Avatar
im not sure what crank was used.... i think its a GSR...my motor also pings under heavy load, changing to bigger injectors will help?
Old Sep 3, 2003 | 08:30 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: what size injectors? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">At least 310's, but you can go as big as you want with Hondata </TD></TR></TABLE>
1600's it is!
Well he said ITR valve train so I will assume ITR cams since nothing else was listed. If you plan on going bigger cams as you should with almost 13:1 I would go mmm 370's - 440's.
HATCHBACK GORILLA!
Oct 8, 2007 09:00 AM
1.8
Jan 4, 2005 04:42 PM
singlecamkilla
13
Nov 5, 2004 06:04 PM
hondaspeder
Jun 22, 2003 03:06 PM
pakman222
Sep 8, 2002 10:08 AM
