5 speed swap... can't find old thread..
Old Sep 2, 2003 | 10:23 PM
doh boy's Avatar
Default 5 speed swap... can't find old thread..
i want to do a 5 speed swap on my 1988 CRX DX... so i have come up with a parts list of what parts i need, if im missing something please help me out...
so far i have:
ECU
Tranny
Tranny Mount
Shift Linkage
Clutch & Flywheel (?)
Pedal Assembly
Clutch Cable
anything that im missing??
Modified by doh boy at 7:44 AM 9/3/2003
Old Sep 2, 2003 | 10:43 PM
doh boy's Avatar
Default Re: 5 speed swap... can't find old thread.. (doh boy)
also, when i buy the transmission i will probably buy a si transmission, so i buy a si clutch right? and for the flywheel is there a difference between the si flywheel and the DX flywheel?
im keeping the Dx motor, just swapping the tranny.
Old Sep 3, 2003 | 12:38 AM
carsaregood's Avatar
you will need an '88 tranny if you use an 88 clutch/flywheel. there are some differences between the years.. i think 88 had a 190mm flywheel, 89 200mm and 90-91 used 212mm. the thing with the '88 tranny is that it uses a 21 splined input shaft...
the bigger flywheels have more friction surface area, so they are able to grip better.
http://www.gamesbbs.com/~dmoore/tranny.htm
this is a useful site for comparing flywheel/tranny/clutch compatibility. if i were you i personally would opt for an '89-'91 tranny, and use the '90-91 flywheel/clutch.
i'm not sure if there are any differences of flywheels/clutches between si and dx models.
while i'm at it... here's a shameless plug if anyone is interested: i have a jun forged cromoly 11lb. flywheel for sale for $250 obo plus shipping. these are over $400 new.
Old Sep 3, 2003 | 11:55 AM
doh boy's Avatar
Default Re: 5 speed swap... can't find old thread.. (carsaregood)
thanks for the help.
am i missing anything from that list or is that all the parts i will need?
Old Sep 5, 2003 | 02:54 AM
i'm not sure about this conversion specifically.. but you'll need lots of little things like tranny fluid, a shifter and ****, a different gauge cluster and console maybe? a shift boot? sorry i'm not being much help.
jdmb20boi
11
Jun 12, 2008 09:27 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
sohcvtec66
Nov 18, 2003 09:49 AM
Civic138
Aug 25, 2003 03:01 PM
