crooked headlight
Old Sep 2, 2003 | 10:08 PM
johnclaunch's Avatar
Default crooked headlight
I was just looking at my driver side headlight the other day and noticed that it was crooked slightly. The side of the light towards the center of the vehicle is lower than the side towards the outside of the vehicle. I know about the screw on the top of the light to adjust the direction of the light up or down, but what about adjusting as for the problem described above? Thanks.
Old Sep 3, 2003 | 05:58 PM
raggedy hatch's Avatar
Default Re: crooked headlight (johnclaunch)
what you can do is loosen up the whole light and then try to correct the problem (light s carry 3 screws) Or if that doesnt work you will have to tweak it to fit either using small washers or drilling new spaces... just try and make sure that your headlight is still aligned and straight to the other ...( sorry this is a shitty answer if u post some close pix' maybe that'll help better) but good luck n e ways!
Blah.
Oct 6, 2008 10:41 PM
sageuvagony
Jun 30, 2008 04:13 PM
animated_life
Dec 27, 2003 12:03 PM
TheBestCRX
Jan 6, 2003 07:19 PM
