think i blew my headgasket?? which one to buy now??
went to check my coolant and there was oil in the radiator. and also, my oil had some coolant in it. which headgasket should i get? i have a sleeved b16 with a 83mm bore with copper o-rings. should i just use a stock honda b16 headgasket? or should i buy some aftermarket one?
Golden Eagle sells overbored Honda headgaskets. Cometic makes overbored gaskets in different thicknesses as well. I think you can't use their HP gaskets with o-rings though, so you'd want their MLS or whatever the regular ones are.
