is it normal for belt to squeak/squeal when wet?
Old Sep 2, 2003 | 08:25 PM
_Endless_'s Avatar
Default is it normal for belt to squeak/squeal when wet?
everytime i drive through a flooded street, i could hear the belt(don't know which one) squeal/squeak when i accelerated out of the flood. it just squeak/squeal upon acceleration and then goes away and does it again if i drive through a flooded street again. i ask my mechanic about it and he said if my belt is not loose then that's normal coz his honda does it too when he drives through a flood.
btw, each time the belt make the stupid noise the car hesitates also like it want to slow down.
is it really normal? or is there something wrong with my belt? i don't know which belt is making the stupid noise but when i check all my belts except timing belt they're not loose and i believe the belts are in the right tension.
Modified by _Endless_ at 1:54 PM 9/3/2003
Old Sep 2, 2003 | 09:49 PM
HulkSmash's Avatar
Default Re: is it normal for belt to squeak/squeal when wet? (_Endless_)
yea it's normal. my alternator belt squeals when i drive through a flood.
Old Sep 4, 2003 | 03:26 AM
.xcalibur.'s Avatar
Default Re: is it normal for belt to squeak/squeal when wet? (HulkSmash)
why even drive when it flooding?
Old Sep 4, 2003 | 06:44 AM
JimBlake's Avatar
That's not completely normal, but it's the first sign the belt is getting old & hard. It'll probably last a long time like that, slowly getting worse until it annoys you enough that you go & buy new belts. What are they, $5 each??
Old Sep 4, 2003 | 07:10 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: is it normal for belt to squeak/squeal when wet? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">That's not completely normal, but it's the first sign the belt is getting old & hard.
What that guy said, It will start doing it when its damp out fairly soon, then all the time on cold starts. Break out the wallet and spend the $4.79
Old Nov 6, 2003 | 07:54 PM
reignofchaos's Avatar
Default Re: is it normal for belt to squeak/squeal when wet? (SIXTYdashONE)
but......... WHICH BELT?? i'm cheap, $15 is a lot for me!
Old Nov 7, 2003 | 03:38 AM
JimBlake's Avatar
Default Re: is it normal for belt to squeak/squeal when wet? (reignofchaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reignofchaos &raquo;</TD></TR><TR><TD CLASS="quote">but......... WHICH BELT?? i'm cheap, $15 is a lot for me!</TD></TR></TABLE>Get some belt dressing, put it on one belt at a time, to see which one makes a difference. That's the one.
Belt dressing will probably help you quiet it down for a while, but it's still on it's way. If you can't afford that, just spray a little water on each belt, one at a time, to listen for one that makes the noise change. That'll only make the noise change for a minute, but maybe enough to show which belt is noisy.
phat00civic
Mar 7, 2012 06:30 AM
NikeSB
Sep 14, 2006 04:23 PM
dizzogotvtec
May 13, 2006 01:49 PM
.Noah Fecks
Feb 8, 2005 12:31 PM
cr-x si
Mar 23, 2003 04:43 AM
