JDM D15B w/ JDM SSO tranny and half shaft, what axles???????
Old Sep 2, 2003 | 06:12 PM
JDMBOLONI's Avatar
Default JDM D15B w/ JDM ZC tranny and half shaft, what axles???????
someone please help me out with this, i'm using the proper passenger side axle but insted of the half shaft and the correct axle i have a stock crx long axle with a teg inner, it works but every once in a while it slips out of the tranny under load because the tranny doesn't use the pin to make the axle stay in because its suppost to have the half shaft bolted to the block. someone help! i just need to know what axle i use on the drivers side for my 88 crx si, thanks H-T!
Modified by JDMBOLONI at 7:28 PM 9/3/2003
Old Sep 2, 2003 | 08:35 PM
R6Boy69's Avatar
Default Re: JDM D15B w/ JDM SSO tranny and half shaft, what axles??????? (JDMBOLONI)
boloni... whats up i need an old crappy 88-91 dx or cx ecu... dont mean to jack your thread so heres a bump
Old Sep 3, 2003 | 08:54 AM
JDMBOLONI's Avatar
doesn't anyone know!!!! i need help!!!
Old Sep 3, 2003 | 09:12 AM
89civicdx's Avatar
no one knows what a SSO is man don't go and tell everyone either!!
I have a SSO on My sohc ZC vtec with the sohc zc half shaft and 90 teg axles....2years & no probs.
Vivek
Old Sep 3, 2003 | 10:28 AM
JDMBOLONI's Avatar
Default Re: JDM D15B w/ JDM SSO tranny and half shaft, what axles??????? (89civicdx)
i can always count on vivek!!! but i thought you needed 88 teg axles?
Old Sep 3, 2003 | 10:36 AM
89civicdx's Avatar
No I used 90 tegs in both the dohc zc and on the sohc...we never changed the axles when we did the swap.
I don't think your d15 has the holes on the back for the half shaft right? Or they might not be tapped.
Oh yeah I just posted pics of the car with the spray paint job in the pics thread at the top check it out...its like the last post.
Old Sep 4, 2003 | 09:24 AM
JDMBOLONI's Avatar
there there vivek, but i have to tap them, boourns, i'll let you know if it works out good! thanks man!
minime-dom
Jul 12, 2009 09:30 PM
sabertooth
Jan 17, 2004 08:35 AM
rasta420
Oct 16, 2003 10:34 AM
udm_motorsport
Sep 23, 2003 05:36 PM
rasta420
Feb 14, 2003 07:20 AM
