Type R sway bar endlink question.
Just got a type r 22mm rear sway bar. Now i have a question about the endlink. Beside the stock type r endlink, will LS, GS, or GSR stock endlink fit to the stock type r rear sway bar?
Thanks for any input.
Yes, the swaybar is essentially the same as the stock Integra bar, just thicker.
It will bolt right up to the stock endlinks.
Another Question.
How about the endlink bushing that attachec on the sway bar (#11 on the picture below)?
Do i need to order a stock Type R one? or they are all the same?
Where did you order the sway bar from? Most of the time, they include all the bushings you need.
When you get the endlinks from a junkyard as you're about to do, the bushings will be in there as well. Won't make a terrible difference if you used the old ones. They are a bitch to replace anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v67-gsr »</TD></TR><TR><TD CLASS="quote">Is that mean all Integra model (LS, GS, GSR, R) all share the same #11 in that picture?
Thanks once again.</TD></TR></TABLE>
YES... all of them have the same #11 & #8
