b16 a both o2 wires hooked up to one o2 sensor
Not a good idea.
http://www.hondata.com/techo2problem.html
Read that and you'll understand why.
O2 sensor for EFs are cheap anyways. 14.99 for a 1 wire. Run it to the ecu in a couple minutes. Only need an O2 bung welded in...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowstylz »</TD></TR><TR><TD CLASS="quote">but the questoin is where do I get the o2 bung welded at ? the same spot they welded my other one? real close to the head.</TD></TR></TABLE>
Yes, about 8 inches down. Have it put in the top part of the header if its 2 piece.
the primary O2 should read all 4 cylinders. Placement is not really an issue, as o2 levels will not change as long as there is not an exhaust leak. The 2nd one, has no feedback to the ECU, its j ust for emmissions. You can usually just get an O2 simulator, or place it after the cat.
redpeppers
28
Sep 24, 2005 06:17 PM
