Honda Wiring f/ Alarm
Found this doing a search. It was mentioned that it was for a 92 Civic. I have a 97 Civic HB are the wiring still the same?
The following is what i found:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white | + |steering column |
| STARTER |black/white | + |steering column |
| IGNITION |black/yellow | + |steering column |
| SECOND IGNITION | | | |
| ACCESSORY |yellow | + |steering column |
| POWER LOCK |green/white | - |2pin plg blue-taped to |
| POWER UNLOCK |green/red | - |blue plg behind f-box |
| PARKING LIGHTS + |red/black | |at fuse box or d.k.p |
| PARKING LIGHTS - | | | |
| HEADLIGHTS |red/white | + |column (low beam only) |
| DOOR TRIGGER |lt. green/red | - |driver kick panel |
| TRUNK/HATCH PIN |grn/blk 2 sil.dot *1 | - |blue conn. above fusbx |
| HOOD PIN | | | |
| TRUNK/HATCH RELEASE | | | |
| FACTORY ALARM ARM | | | |
|FACTORY ALARM DISARM | | | |
| TACHOMETER |blue | |2-pin conn. near dist. |
| BRAKE WIRE |green/white | + |at brake switch |
| HORN TRIGGER |blu/grn, blu/red *2 | - |at steering column |
| WIPERS | | | |
| LF WINDOW UP/DOWN |red/yellow - red/blu | A |drivers switch |
| RF WINDOW UP/DOWN |blue/yel - blue/grn | A |drivers kick panel |
| LR WINDOW UP/DOWN |yellow - yellow/grn | A |dkp, harness to rear |
| RR WINDOW UP/DOWN |yellow - yellow/grn | A |dkp, harness to rear |
NOTES:
*1 On 2 doors, solid green w/ two silver dots.
*2 Models without a drivers side air-bag are high-current ground. Use a relay when interfacing with this circuit.
| HOOD PIN | | | |
| WIPERS | | | |
NOTES:
DA1
Audio / Security / Video
Jan 12, 2006 11:44 PM
