Using a honda O2 sensor vs an aftermarket O2 sensor
Old Sep 2, 2003 | 01:30 PM
97civicdx's Avatar
Default Using a honda O2 sensor vs an aftermarket O2 sensor
Why do Honda cars seem to not like aftermaket O2 sensors? My 97 DX Coupe has a brand new 4 wire O2 sensor from oxygensensors.com. It still throws a 61 CEL which is slow response O2 sensor.
Anyone else have the same problem, and how did u fix it??
Old Sep 2, 2003 | 02:24 PM
AngryTroll's Avatar
Default Re: Using a honda O2 sensor vs an aftermarket O2 sensor (97civicdx)
I don't know what the deal is with aftermarket sensors. Nissan has a ton of O2 sensor problems and they use a lot of the Bosch sensors (you can see the Nissan emblem on the Bosch replacement sensors). You just can't beat Denso and NGK for quality but they are expensive.
Which sensor do you need? I know I have a brand new Sensor 1 O2 and I think I have a brand new sensor 2. Both are factory parts and "untested" (used).
Old Sep 3, 2003 | 08:59 AM
ejprimo's Avatar
Default Re: Using a honda O2 sensor vs an aftermarket O2 sensor (AngryTroll)
i bought a bosch aftermarket O2 sensor for my b16a and to my surprise the O2 sensor said denso on it. i dont know if every bosch O2 sensor is like this.
Old Sep 3, 2003 | 10:08 AM
TheDingo8mybaby's Avatar
are you sure the O2 sensor is the reason you're getting the code?
Old Sep 3, 2003 | 12:35 PM
Daemione's Avatar
Default Re: (TheDingo8mybaby)
I'm using an aftermarket one from oxygensensors.com, no problems with it.
Old Sep 3, 2003 | 12:49 PM
VTEC-DA's Avatar
Default Re: (Daemione)
I am using a Bosch one and its throwing a code 41, o2 sensor heater. My OEM one never threw a code.
phoshyzzle
Oct 18, 2009 07:52 PM
cu3tip
Oct 18, 2004 08:26 PM
