Water leak into passenger side...
Old Sep 2, 2003 | 10:24 AM
LegoZ81's Avatar
Default Water leak into passenger side...
I have a 90 LS and was wondering if water leakage into the passenger compartment from somewhere under the dash is a common problem?
This is rain water/car wash water as I can run the AC at dry times (weather wise no rain) and it is fine however if it rains I get water in the car. When I was at the carwash water would drip from the blower motor area so I am assuming something is messed up in that area. I have not pulled anything apart yet as I have not had time so something could have rusted out or body sealant could have dried up and cracked, or something simular. If this is a common problem or you have had to deal with in the past what are some things I can look for when trying to get this resolved.
Old Sep 2, 2003 | 02:59 PM
cyrk007's Avatar
Default Re: Water leak into passenger side... (LegoZ81)
sounds like a seal on the windshield.. does the inside of the car get icy when cold.. or fogged in the morning? check the seal
Old Sep 3, 2003 | 11:22 AM
LegoZ81's Avatar
Default Re: Water leak into passenger side... (cyrk007)
windshield was recently replaced it was doing this before it was replaced also... so i assume this is not the case, it may very well be though i'll tkae it in and have them look at it.
Old Sep 3, 2003 | 11:33 AM
LS stretch's Avatar
check the seals on the windsheild...u also might have a major hole or sumthin in ure fire wall
dlenoxx
Dec 2, 2010 12:05 PM
hondateg08
Feb 18, 2009 07:58 PM
biscuit01ex
Honda Civic (2001 - 2005)
Apr 30, 2006 11:20 PM
PatrickGSR94
Jan 30, 2005 02:38 PM
Acura97GSR
Jun 26, 2002 07:53 AM
