bore a B16A short blok (ALLMOTOR GURU'S NEED HELP BADLY)
Old Sep 2, 2003 | 09:46 AM
Importracer_001's Avatar
Default bore a B16A short blok (ALLMOTOR GURU'S NEED HELP BADLY)
Whats up guys,
I'm from Holland and I wanted to rebuild a B16A bottom end, but my problem is that I have a B16A bottom end and the stock sleeves are a little damaged when I fried my rings.
How big can I bore the stock sleeves , I'm not gonna run nitrous or turbo on this block.
If it's possible to bore it a little bigger do a I need to reshape my cilinder head chamber???
Please help me out guys
Thanks , I 'll be waiting on your response
Old Sep 2, 2003 | 09:48 AM
mmuller's Avatar
Mad Scientist
Default Re: bore a B16A short blok (Importracer_001)
biggest on stock sleeves: 82mm, if you want bigger, resleeve
Old Sep 2, 2003 | 03:19 PM
civicsitek GanGsTa's Avatar
Default Re: bore a B16A short blok (mmuller)
Take it to a machine shop and have them tell you what the block will have to be bored to. Like mmuller said, 82mm is about as big as you should go, sleeves start to get a bit thin past that.
92egSnatch
Sep 20, 2008 05:27 AM
starcrossed010
Apr 12, 2007 10:13 AM
blue93eg9
Mar 19, 2007 09:22 PM
integrawow
Feb 19, 2007 05:19 PM
Todapwr
May 6, 2003 08:15 PM
