FS or Trade: 1990 Eagle Talon TSi AWD. Only 61,000 original miles.
Ok guys I know this isnt a honda but bear with me here.
Pictures are at [url=http://awdturbo.myserver.org:8080/good%20looking%20car/talonblack.htm[/url]
The car no longer has leather, it has charcoal cloth. And pictures of the motor were before all the new parts went on.
The car for sale is a 1990 Eagle Talon TSi AWD. The car only has 61,000miles on the odometer and is as clean as they come. The car is black with grey trim with charcoal cloth interior. Has a rear LSD. The body has absolutely no rust, and no dings are visible without very close inspection. The car also all new parts with less than 50 miles on all of them the new parts are:
Entire Engine Gasket set w\ head gasket
Removed Balance Shafts
New Water Pump, Timing belt, and Tensioners
ARP Head Studs
RRE Stainless Oil Feed Line
Resurfaced head
Fidanza Lightweight Aluminum Flywheel
6-puck Kevlar DXD Racing South Bend Clutch
New Built TRE Transmission (cost over $1,400) with BG Syncroshift fluid.
New Power Steering Rack, tie rod ends
New front CV Axles
New front brake pads
New fuel filter
Walbro 255lph fuel pump
Trunk Mounted battery
Autometer Phantom Boost gauge with dual gauge pod.
New Magnecore 8mm plug wires.
New Turbo XS MBC
The car runs great with no oil leaks and no typical DSM problems. The transmission is brand new and fully built by TRE, there are no oil leaks, and the car looks great. The exhaust cam was advanced one tooth for more horsepower so the idle is a little lumpy, but even with no balance shafts the idle is smoother than most DSM's ive been in. Call Luke at (574) 234-7595 after 5pm and leave a message if im not around. Email Sjcv64@aol.com with any questions. Thank you
Asking $4800 or best offer.
_____________________________
Modified by 92tealTSI at 5:23 PM 9/24/2003
ARP Head Studs
Resurfaced head
New front CV Axles
New fuel filter
New Turbo XS MBC
i cant get the link above to work for the pics...?
email them to me if needed
jmsski@aol.com
why no more leather?
jmsski@aol.com
The leather was sold to put more money into the car, but the cloth interior that is in it now is just as supportive and in perfect shape.
