biggest cams in a stock itr ?
Old Sep 2, 2003 | 08:54 AM
madhatch's Avatar
Default biggest cams in a stock itr ?
what are the largest cams poeple are running on the stock valvetrains? Looking to get some new cams, just curious on your advice.
Old Sep 2, 2003 | 08:58 AM
advanracing62's Avatar
Default Re: biggest cams in a stock itr ? (madhatch)
stage I cams- SK2, JUN, Coward... Rocket may be able to suggest some EF-1 components for the set up.
Old Sep 2, 2003 | 09:48 AM
b19coupe's Avatar
Default Re: biggest cams in a stock itr ? (advanracing62)
Toda 'A's will also work with the stock valve train. Get cam gears and hit the dyno to max any gains from whatever cams you end up purchasing.
Old Sep 2, 2003 | 10:11 AM
Cheap Bastard's Avatar
New User
any cams will work, just stay with stock rev limit. 9k rpm, large cams, and stock valve train = bad/danger.
Old Sep 2, 2003 | 10:29 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: biggest cams in a stock itr ? (Cheap Bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheap Bastard &raquo;</TD></TR><TR><TD CLASS="quote">any cams will work, just stay with stock rev limit. 9k rpm, large cams, and stock valve train = bad/danger.</TD></TR></TABLE>
Yep. I put 10k miles on Toda B's with stock valvetrain.
[edit] Though I wouldn't try it with anything lumpier than a B [/edit]
Old Sep 2, 2003 | 12:31 PM
madhatch's Avatar
Default Re: biggest cams in a stock itr ? (Splat)
awsome. Thanks fellas
Old Sep 2, 2003 | 01:22 PM
madhatch's Avatar
anybody tried crane cams?
The Si
Feb 22, 2007 03:17 PM
DA-9mordef
Apr 27, 2006 10:04 AM
digital sol
Apr 26, 2006 10:42 AM
tegsallgood
Nov 11, 2004 11:00 PM
